Panasonic 45mm vs Olympus 60mm macro
Started Jan 6, 2021 | Discussions
Interceptor121 Veteran Member • Posts: 8,691
I got a practically new 45mm from mbp box intact all parts except user manual the lens was still at firmware 1.0 and really seems to have zero use. It is not decentred so all good.
Started making some comparisons with the Olympus 60mm on my EM1MKII body using a G9 body
Obviously the cameras despite same setting and almost identical framing (magnification is different) do have different response to colors and natural light more than the lenses do it would seem. It is quite apparent that there are tweaks to the middle grey as well.
Anyway little comparisons of the two on small miniatures close up (not macro yet)
It puzzles me that the jpeg Dxo generates is 31.8MB for the G9 and 22.7 MB for the EM1II there is not much in the frame other than the miniatures?
Exposure settings and color temperature are the same focal length obviously is not
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Happy Daze Contributing Member • Posts: 568
Re: Panasonic 45mm vs Olympus 60mm macro
The larger file size would probably indicate that there is more detail in the image perhaps sharper edges or more of the image is in focus. Differences in the number of colours in the image (perhaps in gradients of OOF areas) will also affect the jpeg file size.
(unknown member) Forum Pro • Posts: 19,317
a larger file is more recorded noise.
Don
Olympus EM1mk2, Sony A7r2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1 em5mk2
OP Interceptor121 Veteran Member • Posts: 8,691
Don
Unlikely they both went to the same denoising process
Didier_FR92
Didier_FR92 Forum Member • Posts: 73
Hello,
Sorry if it is obvious, but I don't see any exif data, so wich is which ?
 Didier_FR92's gear list:Didier_FR92's gear list
Olympus E-M5 III OM-1 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
Sorry don't know why that happened the 60mm is the first photo 45mm the second
Is very hard to tell even looking at the background compression seems the focal lenght difference is less
Bassam Guy Veteran Member • Posts: 4,885
Both noise and finer detail could explain the size difference.
Sharper edges cause fewer distinct pixels, not more, as there are fewer transitional colors.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
It would be more meaningful to use lossless compression for this test. Lossy compression (e.g. JPEG) introduces another set of possibilities. Try PNG16.
