Question about e-shutter on R
Started Jan 4, 2021 | Questions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Does anyone know why the electronic shutter on the R is available in single shot and high speed continuous (5fps) modes, but not in low speed continuous (3fps)? It seems strange that you can shoot e-shutter at 5fps, but not 3fps. Perhaps there’s some technical reason I’m not aware of?
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
juanmaasecas Senior Member • Posts: 1,497
Re: Question about e-shutter on R
It seems that the same happens in R5/r6. Electronic shutter only works in 20 FPS there, go figure.
I don’t know the reason.
 juanmaasecas's gear list:juanmaasecas's gear list
Canon EOS M50 Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF-M 22mm f/2 STM Sigma 35mm F1.4 DG HSM Art +4 more
philmar Senior Member • Posts: 2,666
I don't even know what e-shutter" is....I've looked in the paper manual and it makes no mention of e-shutter in either the Table of Contents or Index.
How did you learn about it?
Phil M. - Toronto, Canada
Time to kill? Then have a look at a few of my photos: https://www.flickr.com/photos/phil_marion/albums
You will NOT be disappointed.
 philmar's gear list:philmar's gear list
Canon EOS 5D Mark III Canon EOS R Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM +3 more
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
Sorry. e-shutter is electronic shutter. On the R, it's called silent shutter. The R has three shutter modes: full mechanical, electronic first curtain, and full electronic. Full mechanical is pretty much what all film cameras had. You have two shutter curtains. First, one opens, exposing the film or sensor, and then the second closes. For exposure shorter than the flash synch speed, the second curtain starts closing before the first one finishes opening, so you actually get a band of exposed film/sensor that travels across. Which is why you need to use high speed synch on a flash to shoot with shutter speeds higher than the synch speed (the flash fires multiple bursts). Electronic first curtain starts with one mechanical curtain already open, activates the sensor, then closes the second mechanical curtain. Fully electronic (silent shutter) starts with the shutter open (which it is most of the time, otherwise we wouldn't be getting a view from the sensor), and simply activates the sensor for the specified amount of time. But in pretty much all modern sensors, the activation doesn't happen across the whole shutter at once, but happens in waves across the sensor (a bit like the moving curtain of a mechanical shutter). This is what can cause what's called "rolling shutter", which can distort how things look, if they, or the camera, are moving during the exposure. At some point soon(ish), we'll get cameras with "global shutter" in electronic mode, which will have the whole sensor exposed at once. This will eliminate rolling shutter, and enable high flash synch speeds.
A confusing thing about the R is that the shutter modes aren't simply called what they are. Electronic shutter is called "Silent Shutter". Electronic first curtain is called "Silent LV shooting" (mode 1 or 2). And full mechanical shutter is simply what you get when you select "Disable" for Silent LV shooting.
Alastair
David Franklin Senior Member • Posts: 1,692
I really think your work is excellent, among the best amateur landscape and architectural work I've seen, and in 2020 - the portfolio I viewed - it was all in your own home town, perhaps your metaphorical "back yard." Very impressive.
However, it's hard to believe that you really don't know the other poster is talking about the electronic shutter when he refers to the "e-shutter", but if you didn't know, now you do.
Keep learning; share knowledge; think seriously about outcomes; seek wisdom.
 David Franklin's gear list:David Franklin's gear list
Canon EOS R5
