Nikon D5600 Reset
lou17
lou17 Forum Member • Posts: 84
Nikon D5600 Reset
I'm having trouble with setting up my D5600. I would like to know how do I reset my camera like it just came out of the box. thanks in advance.
Nikon D5600
Mark Scott Abeln
Mark Scott Abeln Forum Pro • Posts: 16,809
Restoring default settings
 Mark Scott Abeln's gear list:Mark Scott Abeln's gear list
Nikon D200 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 28mm f/2.8D +4 more
BrownieVet Senior Member • Posts: 3,648
TWO-BUTTON reset
Re: Nikon D5600 Reset
You need to READ the Manual
or watch the Video Tutorial . . .  use Google to search the intrnet.
FrancoD Forum Pro • Posts: 14,468
"To perform a reset you need to manually choose the reset option in the Shooting Menu and the Setup menu. To do this press 'Menu', select the Shooting Menu and scroll through the options until 'Reset Shooting Options' is highlighted, press ok, highlight 'Yes' and press ok again. Repeat this for the Setup menu.'
You can also press both Green buttons (Menu and Info) simultaneously for a few seconds, does the same thing.
