Olympus vs Panasonic 30mm macro
Started Dec 31, 2020 | Discussions
chad515
chad515 Regular Member • Posts: 316
I think I'm going to buy a 30mm macro, and I'm wondering which I should get. I'll use it primarily for product photos and photographing artwork, though I'm sure I'll dabble in tiny stuff at some point. Macros seem to be the best choice for photographing artwork and products, and I'd actually prefer the 30mm distance to something longer so I don't have to be too far away. I also will likely end up using it as a normal prime, giving me something in between my Panasonic 20mm and my Olympus 45mm.
I lean toward the Olympus, as it's on sale for $224 right now (as opposed to $398 for the Panasonic). I know the Panasonic gives f2.8 instead of f3.5, but that difference doesn't seem enough to justify the extra cost. Is there a large sharpness difference? Or some other reason to go with the Panasonic?
This will be used on a Panasonic GX85, which means I'll have IBIS either way. The Panasonic would give me dual IS, which is better. But again, I think perhaps not enough better to justify the extra cost.
 chad515's gear list:chad515's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Rokinon 7.5mm F3.5 UMC Fisheye CS Panasonic Lumix DMC-GH1 +8 more
Olympus 30mm F3.5 Macro Panasonic Lumix DMC-GX85 Panasonic Lumix G Macro 30mm F2.8
jalywol
jalywol Forum Pro • Posts: 12,302
Re: Olympus vs Panasonic 30mm macro
I can't tell you about the Panasonic, as I have the Oly.  I do like the Oly VERY much, and it's a very good value when on sale.  (I have seen them as low as $149).  The Panasonic does also go on sale for about $100 off, if I recall, but right now they are at full price everywhere, so you may want to hold off for Jan to see if there are any new sales afoot then for either lens.
What I will say to you is that the IBIS in the GX85 is not terrible, but it's not exceptional either, so having the OIS in the lens might not be a bad idea.  I can do ok with the IBIS in the GX9 (same as you have in the GX85), but it's definitely not as effective as having either lens IS or Dual IS, which I do have in other Panasonic lenses of a similar focal length (a couple of zooms).
Your call on that, though.  If you do plan to use it on a tripod for product and artwork photos, than the extra lens OIS will be irrelevant, and I would heartily recommend the Oly.  If you do plan to do more general use, you may wish to evaluate how steady you are with your other un-stabilized lenses to see if the OIS will significantly impact your planned usage parameters.  If not, definitely get the Oly, it's a very nice lens and a very good value.
-J
nsd Forum Member • Posts: 65
IME stabilization of either kind doesn't work at macro distances. At 1:1 reproduction & 20Mpx sensor, a shift of 3 microns in position (0.003 mm) shifts the image by 1 pixel. I assume the IS movement sensors aren't able to accurately detect a movement that small.
Jeff Wahaus Contributing Member • Posts: 943
It sounds like you won't really be using it for macro work most of the time.  60mm requires you to get very close at 1:1, for the 30mm it's much worse.
Most standard lenses will let you get close enough for product and  artwork photography.   If the 30mm focal length appeals to you than a wider aperture prime may be more useful than a smaller aperture macro lens.  Like a 25mm f1.8 (or f1.2 if you can afford it).
 Jeff Wahaus's gear list:Jeff Wahaus's gear list
Olympus E-M1 III Olympus OM-D E-M10 IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +6 more
Jim Vincent Veteran Member • Posts: 3,034
The OP said a primary use would be for photographing artwork.  A 30mm macro with it's flat field seems an excellent choice for this.  He's not looking to get 1:1 or anywhere near that close to what he's photographing so IBIS should be fine.
I expect either lens will work well for the OP's intended use - it's up to him which is more important - a little larger f/stop or $$ in his pocket.
 Jim Vincent's gear list:Jim Vincent's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 7-14mm F2.8 Pro Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS
bluevellet Veteran Member • Posts: 4,172
The Panny is technically the better lens. But... the Oly can be had cheap, super cheap. I got mine direct from Olympus, brand new, for a little over 100 bucks. Wait for a sale.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
april fox Contributing Member • Posts: 862
That’s why Olympus sold their camera arm ..... too many people were interested in items at sale time only.
Sales good for the consumer not so good for the producer and in the end not so good for the consumer as the producer leaves the game
chad515
OP chad515 Regular Member • Posts: 316
Yes, the main draw is the flat field, particularly for photographing artwork. I currently do it sometimes with the Panny 20mm, or sometimes with an old Canon FD 50mm macro. The 20 works OK, but the edges are not as nice as the center. The legacy macro is better at that, but requires more work to get focus just right and also more work in post to get contrast and colors to look good. Plus the 50mm focal length means that for larger pieces of art, I have to be further away, which is especially difficult when the artwork is laying on a table (yes, I have a ladder, and yes, I'm tired of using it).
chad515
I haven't been following sales. How often do they happen? Are they happening during the pandemic? Seems like lots of sales haven't been as regular lately. I presume you're saying the current $75 off sale for the Oly isn't that good, right?
Thanks.
Thanks.
Isn't there a sale every month or so? Bought mine in Spring.
With the transfer to JIL, I'm not sure what's going to happen. There's always Ebay with used or refurbished items if that is no longer an option.
jalywol
Thanks.
I'm not sure you are going to get the Oly for less than $224 in a hurry.  It has been as low as $149, but not recently, so I think around $200 is more likely to be the best you can do if they bump the sale up a bit in the next couple of months.  Panasonic, for sure, does sell their 30mm macro for $100 off; $297 was their pre-Christmas pricing on it, so I would expect that to come back again certainly by February for the President's Day sales.
A couple of years ago, Oly had a Black Friday sale on the 30mm macro for $99.  I ordered two of them at that price, and it took them about two months for them to catch up on the back orders.  I ended up selling the second one for $149, as did I think half the folks who jumped onto that special .  Oly did NOT make that mistake again.  So, I think $225, if you need to use it sooner rather than later, is about the best you will probably be sure of seeing it for on sale these days.  It might go down a little bit for President's day, but I suspect not so much.  The Panasonic, for sure, will end up being on sale for $300 if you give them a few weeks.
-J
Skeeterbytes Forum Pro • Posts: 23,186
I don't know if the Oly 30 is based on the 4/3 35/3.5 macro, guessing it might be and if so, it's suitable for the task. I still use the old lens for just that purpose because it's sharp edge to edge with no noticeable field curvature or light dropoff.
Pricing on the 30/3.5 seems to make it an easy choice.
Good luck!
Rick
alcelc
alcelc Forum Pro • Posts: 19,003
Do you shoot on tripod?
If so, either ok.
If on handheld, I shall look for the Panny OIS lens because  of DUAL IS on GX85.
If the Oly lens is used, you could expect an effective IBIS of 2+ stops max. DUAL IS of Panny 30 on GX85 could expect 4+ stops (to certain larger lens I enjoyed 5 stoos)...
Albert
** Please feel free to download the original image I posted here and edit it as you like **
chad515
Re: Do you shoot on tripod?
alcelc wrote:
If so, either ok.
Yeah, if I can find a deal on the Panny (either official or maybe ebay), I may go that route. Much of this is either on a tripod or using off-camera flashes, so the OIS won't matter. But having a prime with dual IS might give me more extra uses (e.g. handheld video).
chad515
Oh, one other question. How is the focus speed and noise on these two? For artwork and products, it won't matter. But I wonder about other uses (e.g. handheld AFC video). My Panny 20mm f1.7 is a fantastic lens, but I won't use it for many scenarios because it's focusing is so loud and slow.
Thanks in advance.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the extra stop does not matter in most macro shooting, so that would not be a reason to buy the pansonic.
The reason to buy the panasonic is duel IS and lens characteristics,  I got the oly on a better deal, and find it a fine macro lens.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
i thing 225 is a ok sale for this product, the 100 was a one time thing I think.
Peter Lacus
Peter Lacus Regular Member • Posts: 180
As with other Olympus MSC lenses I hardly hear anything during the focusing, but the AF speed is perhaps a bit slower than on a general purpose lens, especially if it needs to go through the whole range (but that's normal for a macro lens). I don't have the Panasonic so no comments on that lens.
 Peter Lacus's gear list:Peter Lacus's gear list
Pentax Q Nikon 1 J1 Pentax K-01 Fujifilm X-M1 Panasonic Lumix DMC-GM1 +10 more
AndyH44 Veteran Member • Posts: 3,112
Tried both when I had my Lumixcameras and much preferred the Lumix 30 over the Oly 30.  Noticeably better I.S. and f2.8 is nicer as well.
"True craftsmen never blame their tools, but strive to use them properly"
chad515
That's very helpful. Thanks so much. Did you notice any difference in image sharpness, focus speed, or focusing noise/loudness?
