RF 50mm f1.8 stm review.
Started Dec 29, 2020 | Discussions
R2D2 Forum Pro • Posts: 26,531
Re: RF 50mm f1.8 stm review.
quiquae wrote:
R2D2 wrote:
pawn wrote:
Swerky wrote:
The digital picture have finished the review of the RF 50mm 1.8. Wasn't the larger mount diameter supposed to bring, among other things, less vignette to the image? Perhaps I'm wrong.
https://www.the-digital-picture.com/Reviews/Lens-Vignetting-Test-Results.aspx?FLI=0&API=0&FLIComp=0&APIComp=0&Lens=1528&Camera=1508&LensComp=989
Thanks Swerky for sharing
I know that vignetting can be corrected in software. What are issues in doing this correction in software? Some people even add some vignettes to their images.
It can add noise and/or lead to loss of detail (no free lunch). It also takes more time and processing cycles.
R2
The processing cost is negligible--it's just one of many corrections that go into RAW processing.
It certainly slows down my workflow (DPP).  I keep all NR, Sharpening, DLO, etc turned off in-camera and apply later in post when needed.  DPP is a dog even with a new PC (but I like its output  ).
It may not impact your own workflow (and I put up with it), but I was just answering Pawn's query above.
The noise problem is real, though.
That too, although it may or may not be impactful.
R2
sportyaccordy Forum Pro • Posts: 20,562
Wow, really no improvement from the mediocre EF version.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
tkbslc Forum Pro • Posts: 17,522
Not a lot.  It's kind of like a mark II of the 50mm STM.   The corners definitely are less hazy, but not a ton sharper.   The profiles are better and actually smart-sharpen the RF 50mm quite a bit, so real world results look quite a bit better on the RF.
For $199 I didn't expect a big upgrade.   That $75 let me get rid of the adapter and added a control ring.  That was worth it for me.
I haven't seen as big of a vignetting difference as TDP is showing, but maybe my camera is hiding it from me.
I guess if size a huge deal then it's an upgrade. But I'd rather have the adapter + 50 STM for the same money as I have other EF glass. Just such a disappointment. I think Canon could have really upgraded the optics while maintaining the small size everyone is going insane over. Oh well. Waiting for Samyang.
thunder storm Forum Pro • Posts: 10,139
Well, at least the newer one gets sharp across the frame at some point. So compactness is a reason to get the RF 50mm f/1.8.
At the same time a lot of zooms do a very good job at 50mm, so compactness is the only reason to get it.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
MAC Forum Pro • Posts: 18,487
exactly
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
OP Swerky Contributing Member • Posts: 793
And f1.8 even though it's not sharp there
It is amazing how a lens hood can give an air of professionalism to whatever kit I may have.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
Claire Dupuis Senior Member • Posts: 1,917
shawnphoto wrote:
I LOVE vignetting in a lens, I find modern optics clear edge to edge wide open sad enough to make me cry. A little darkened corners give depth and character to a lens, I'm so glad this one exhibits some !
I find heavy vignette to be the realm of cornball photography. A small amount of vignette is pleasant and adds a subtle depth to the image. 1-2 stops max in the corners. Even then it will look stupid against a clear sky and require removal.
I agree with you, we don't need heavy vignetting, but a slight amount of darker corners create a visual natural "frame" to the image, which I find pleasant. No vignetting whatsoever makes me think of medical use glass, cold and sterile and brrrrr... don't like it. I turn pheripheral correction OFF on ALL my cameras when I first get them
"If you don't have an expression, then you don't have a shot" - Peter Hurley
You can add vignetting and other "character" qualities (aberrations) in post
