RF 50mm f1.8 stm review.
Started Dec 29, 2020 | Discussions
Swerky Contributing Member • Posts: 793
The digital picture have finished the review of the RF 50mm 1.8. Wasn't the larger mount diameter supposed to bring, among other things, less vignette to the image? Perhaps I'm wrong.
https://www.the-digital-picture.com/Reviews/Lens-Vignetting-Test-Results.aspx?FLI=0&API=0&FLIComp=0&APIComp=0&Lens=1528&Camera=1508&LensComp=989
It is amazing how a lens hood can give an air of professionalism to whatever kit I may have.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
Karl_Guttag Senior Member • Posts: 1,883
Re: RF 50mm f1.8 stm review.
I think that was the technical reason they gave for the RF mount over say Sony's E mount.  But then it seems all the canon lenses, even the L-lenses have significant vignetting without any digital correction (seems to get mentioned in every technical review). I don't think any of the vignetting is being caused by the diameter of the opening, but more a factor of the lens design.
At the same time, there is amazing little chroma aberrations after correction. I wonder if these issues are linked. It feels like the Canon designers are designing lenses with correction expected. The let parameters go that can be corrected in software. Of course, correction comes at some cost.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
R2D2 Forum Pro • Posts: 26,531
6
Only when the lens design utilizes that advantage, as in the new RF 35mm f/1.8...
New RF 35 f/1.8 design on right.
However the new RF 50mm f/1.8 didn't incorporate a lot of that...
RF 50 f/1.8
Images courtesy TDP.
R2
shawnphoto Senior Member • Posts: 1,307
Welcome to the brave new world.
Biden will save us!
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
moon1029 Regular Member • Posts: 304
I think that's a lens design trend rather than for technical reason. The EF 16-35 f/2.8L III has far more vignetting than the II version, and the RF 15-35 and EF-16-35 f/2.8L III are similar in this deparment. Canon's engineers are probably trading sharpness and contrast for vignetting.
 moon1029's gear list:moon1029's gear list
Canon EOS R5 Canon EOS R6 Canon 85mm F1.4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 70-200 F4 L +6 more
The vignetting looks serious on the test chart. In real world use, with the low noise performance of R5/R6 at ISO as high as 25600 that's not a problem. Even after peripheral correction there is no visible noise in the corners. That's my experience with the RF 35mm f/1.8, which also has heavy vignetting on test charts.
OP Swerky Contributing Member • Posts: 793
I don't know if vignetting is related to sharpness and contrast, but yes as you mentioned the EF 16-35 II has noticeably less vignetting than the third version, thus vignette is not only related to mount diameter and the lens design that takes advantage of that. Although I haven't checked in what area the 16-35 III is better than the II.
RDM5546
RDM5546 Senior Member • Posts: 3,654
I think the lenses are designed with greater consideration for the corrected image quality and less consideration for the pixel peeping in RAW images.   Their goal being to further distance them and their imaging performance from the camera evaluation metrics used by customers of the encroaching hordes making  smartphone alternatives.  Greater computational enhancement in camera using AI software in-camera and during post processing is the future of photography and video media creation.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Claire Dupuis Senior Member • Posts: 1,917
7
I LOVE vignetting in a lens, I find modern optics clear edge to edge wide open sad enough to make me cry. A little darkened corners give depth and character to a lens, I'm so glad this one exhibits some !
"If you don't have an expression, then you don't have a shot" - Peter Hurley
sobrien
sobrien Senior Member • Posts: 1,756
The RF mount diameter isn’t larger than the EF one.
The RF flange distance is shorter, though, which I understand means light hitting the sensor at more oblique angles which I believe could contribute to the greater vignetting, though I stand to be corrected on that by someone who understands this stuff better than I do.
Perhaps I'm wrong.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
Flange distance and Sensor Illumination Angles
Perhaps I'm wrong.
It is a very interesting question as to how much the illumination angle of the sensor affects the vignetting. A simple sensor illuminated at an oblique angle would be expected to have vignetting effects in the corners, Things like microlenses on the sensor would help but not eliminate the issue.
I'm don't know what The Digital Picture is doing to test the Lens. It looks like they are using some kind of lab equipment and not just taking pictures with the camera for the vignetting image.
It would be interesting if some cameras/sensors exhibit more or less vignetting with the same lens.
I find heavy vignette to be the realm of cornball photography. A small amount of vignette is pleasant and adds a subtle depth to the image. 1-2 stops max in the corners. Even then it will look stupid against a clear sky and require removal.
Biden will save us!
tkbslc Forum Pro • Posts: 17,522
The mount diameter is the same as EF.
axlotl Senior Member • Posts: 2,273
RF 50 f/1.8
R2
I have both RF 50mm f1.8 and RF 35mm f1.8 and they each exhibit substantial corner shading of similar degree despite their different approaches to lens design.
Andrew
R5, 50mm f1.8 at f11  hand held.
That review is thorough as  usual from Bryan Carnarthan. However I think he ends up underselling the lens a bit, I wonder if he got a slightly-not-quite-up-to spec copy ?
His copy did not show sharp corners until f11. Mine is sharp in the corners from f4-f5.6. He also describes the lens as being suitable for "beginners and kids..." My experience is that it can deliver very high levels of image detail  on the R5 and is entirely suitable for enthusiast and/or professional use.
Andrew
RF 50 f/1.8
R2
Andrew
I own both also, and the 50 exhibits more vignetting than the 35 (they’re indeed both pretty heavy). The 35 also has better corners overall. Maybe there’s copy variation, but my observations line up with those from TDP.
R2
pawn Veteran Member • Posts: 3,261
Thanks Swerky for sharing
I know that vignetting can be corrected in software.  What are issues in doing this correction in software?  Some people even add some vignettes to their images.
It can add noise and/or lead to loss of detail (no free lunch).  It also takes more time and processing cycles.
R2
True vignette can be attractive in some cases, but it is nevertheless a flaw, and removing it in post introduces noise. Specially against the sky, noise can be pretty obvious the more the vignette is heavy.
quiquae Senior Member • Posts: 2,265
R2
The processing cost is negligible--it's just one of many corrections that go into RAW processing. The noise problem is real, though.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
