Need help for Canon 90D C.Fn II autofocus settings for birding
adonetok Regular Member • Posts: 145
In Canon 90D how to setup 16 parameters in C.Fn II autofocus still confused me.
Is there a good link to learn from there to get sharp birds photos?
Fastfreddy74 New Member • Posts: 14
Re: Need help for Canon 90D C.Fn II autofocus settings for birding
This is for the 80D, but the function of the settings are the same on the 90D
https://www.grantatkinson.com/blog/canon-80d-setup-for-wildlife-photography
1Dx4me
1Dx4me Forum Pro • Posts: 11,348
what lens do you use, your lens might be the culprit here!
Absence of evidence is not evidence of absence!
OP adonetok Regular Member • Posts: 145
Canon 400mm/5.6 Prime
Myer Veteran Member • Posts: 3,254
The main settings for AI Servo are in C.Fn:Autofocus.
Let's start at #7 and work backwards.
Depending upon how steady you are, how far away the bird is and what kind of background you want to select one of the first three.
#6 I'd use 0
#4 and #5. What good is speed if you don't have focus. So go with focus on both.
#3. This is for switching between focus points. If you are using single point this does nothing. Otherwise I'd go with +2.
#2. I'd go with +2.
#1.
And the reason I left it for last. If you are in a situation where the birds are flying thru trees, etc then once focus is locked on you want to keep it. So go with -1 or -2.
If you have a nice clear sky, your birds are generally above the tree line and moving to and away a lot then you want the camera to keep refocusing the lens as the birds move. So +2 would be good.
