Which IOS App with Panasonic GM5
Started Dec 25, 2020 | Questions
bs1946
bs1946 Veteran Member • Posts: 7,779
I just bought a GM5 which will be arriving tomorrow. When, I went to the Apple App Store to download the WiFi App to use with the GM5, I found two similar apps; the Panasonic Image App and the Panasonic Lumix Sync App.
When I previously owned a GX7 and later GM5, when the GM5 first came out, I probably used the Panasonic Image App, which is referenced in the GM5 User Guide, and I don't remember if the Panasonic Lumix Sync app existed back then.
My question is, can either app be used with the GM5 and if so which is the better of the two to use?
Bill S.
www.flickr.com/photos/wrs1946
instagram.com@billschaffel
“Sharpness is a bourgeois concept”
– Henri Cartier-Bresson -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX7
pannumon Veteran Member • Posts: 4,130
Re: Which IOS App with Panasonic GM5
Lumix Sync is only compatible with:
S series: DC-S1 / S1R / S1H / S5
G series: DC-G100 / G110
The correct answer is Panasonic Image app.
Back in the day there was also a third app. I don't remember the name anymore.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
bs1946
OP bs1946 Veteran Member • Posts: 7,779
Thanks, appreciate the info.
Bill S.
