Olympus 60mm f/2.8 Macro vs. 30mm f/3.5 Macro
Started Dec 24, 2020 | Questions
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Re: Face with thirty...
I could not tell how close up the OP wanted to shoot, but you can choose whatever you like with the lens,
if you need to shoot super close, get a ring light.
it is a 1.25 macro
it basically can focus anything in front of it with a tiny min focal distance.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
BBbuilder467 Veteran Member • Posts: 7,057
it is a 1.25 macro
She should never need more than 1:2, but that puts the lens within 2 inches of her eye. She might not be able to see the LCD with that working distance. She could do a head and shoulders portrait from arm's reach at 30mm, but not 60mm.
I can mimic what she's doing with the 30mm f/2.8 and the articulating lcd of a Panasonic, but don't think I could with a tilt type. I couldn't see it.
Helen
Helen Veteran Member • Posts: 7,606
it is a 1.25 macro
The OP's current camera, the E-PL8, has a tilt LCD that will fold down below the camera all the way to a vertical position, to face forwards.
it is a 1.25 macro
Can you see the LCD when the lens is only 2 inches from your eye? With the articulating, I can use my right eye to focus on my left. I don't think I could do that if the LCD was above or below.
pannumon Veteran Member • Posts: 4,130
Yeah you need to shoot in portrait orientation.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
jalywol
jalywol Forum Pro • Posts: 12,301
Oly 30mm, for what you want to do.
7
Personally, for your purposes, I would go with the 30mm. I have one, and have also had the 60mm, and the PL 45mm. Of the three, the 60 is my least favorite, for a few reasons, none of which have any particular bearing on your uses EXCEPT that it is some inches longer than the 30mm, which might make it harder to maneuver if you are using it selfie-style to shoot your makeup.
The only one of the three that I ended up keeping is the 30mm, by the way, as I think it does a stellar job in a very small lens body. The PL 45mm has really beautiful output, but it's way too expensive for what it is, and the 30mm actually approaches it in IQ, for a whole lot less cost.
There is also another macro lens to consider: The Panasonic 30mm f2.8 macro. I have not used that one, but it gets universally praised by those who have it. It's more expensive than the Oly (which is the real value/bargain of the batch if you can get it on sale), but it has a faster maximum aperture (f2.8), and also has built-in stabilization. Now, you do have stabilization in the EPL8, but it's a slightly less effective stabilization (3-axis) than in some of their upper end cameras, and I suspect the in-lens stabilization in the Panasonic might be better than the camera stabilization that the EPL8 has. (I also think the in-camera stabilization (IBIS) in the EPL8 might have a harder time with the longer 60mm Oly macro than it would with the 30mm Oly macro, because the longer the lens, the more fussy it is about needing more sophisticated stabilization).
In any case, after all that, I think the 30mm focal length lenses will be a very good choice for your purposes, no matter which one you get. The 30mm Oly is by far the best value for the dollar, if you can get them on sale, of the batch, and certainly an easy way to get into macro to see if it is what you need for your desired uses.
-J
Steppen wolf Regular Member • Posts: 122
Re: Olympus 60mm f/2.8 Macro vs. 30mm f/3.5 Macro
ScottoG wrote:
Steppen wolf wrote:
One factor that may or may not be of interest is that the 60mm f2.8 is compatible with the in-camera focus stacking on the later Olympus cameras, whereas the 30mm isn't. I use focus stacking quite a lot on my EM5 mkIII and it's very useful for macro.
Sorry, but I wish to correct your statement. The Olympus 30mm macro lens is also compatible with Olympus bracketing and stacking.
(And, yes, stacking is great on the E-M5, isn't it!)
Apologies - I thought the 30mm wasn't on the list, but I see it is.
Another option for a lens might be the new 12-45mm f4, which isn't true macro (more like 1:4 wide or tele) but has very close focus indeed and is a step up in IQ from the standard 14-42. I use mine a lot for close ups when I don't really need full macro. It's also compatible with focus stacking but you need the up to date firmware (1.2 IIRC). I tried it without and just got a real mess.
OutsideTheMatrix
OutsideTheMatrix Veteran Member • Posts: 9,876
Based on everything I read, isn't focus stacking out of camera better than focus stacking in camera?  There is good freeware that can do it and it is more flexible and can combine more images than what you can do in camera.
also I love the 60mm f/2.8 macro it is the best macro lens and is quite inexpensive.
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
OutsideTheMatrix
Bassam Guy wrote:
sevenpeanuts wrote:
Hi everyone! I am a beauty photographer, and I take photos of my own makeup. I have an Olympus PEN EPL8. Typically I take photos of my eyeshadow, but occasionally I take photos of my entire face or parts of it. Here is an example of what I currently do:
<Photo of beautiful eye removed for brevity>
When I take my photos, I am holding the camera in my hands while sitting at a desk where my lighting set up is. I am concerned about having to be too far away from my subject (my arms can only go so far from my face), so I lean towards the 30mm in that aspect. However, I have heard that the 30mm would not do well at anything besides macro shots, or that it might distort the proportions in some way. I am new to the world of photography, so I have a hard time understanding if I'd be able to photograph my whole face (or parts of it) using the 30mm, which makes me consider the 60mm instead.
Knowing all of this, do any of you have suggestions on which lens I should go with? Please let me know if there's anything I can answer to help the recommendations.
Lighting is important.
The minimum focus distance from the 30mm front element to subject is .6" (1.5 cm). Not only could a long eyelash graze the glass but you haven't much space to easily provide good lighting.
The 60 will give you much more lighting flexibility as well as great portraiture (and quelled my lust for the 75 1.8).
The video that my homeboy, vermont3133, linked above (https://www.youtube.com/watch?v=LSb9oSeEGII) is worth watching. I'm not sure if the reviewer used the 60's focus limiter properly (usual cause of its hunting) and I see a greater IQ superiority than he did in the 60 vs the others. Ignore the conclusion, as you should weigh the categories according to your needs, not the reviewer's.
Another benefit I get from the 60 is the weather sealing. My rainy day hiking kit is the 12-40 2.8 plus the 60 2.8. But, of course, for indoor eye closeups, that means little unless the 60 brings you as many tears of joy as it did me.
60mm f/2.8 macro is the best macro lens that Oly makes.  That would be my main lens for flower macros.  I dont think the 75mm f/1.8 is a macro lens....I'm considering getting that for astrophotography because it's a super bright lens.
tedolf
tedolf Forum Pro • Posts: 29,547
Distortion....
Cyvan wrote:
That is a gorgeous shot and if that's of your own eye its even more amazing. I've taken macro shots of my eyes before and it's NOT easy.
I have the 60mm and its a great lens. The longer focal length is good for insects etc so you don't have to get too close which would scare them away.
Here's the min'm focal distance of the lens with my hand in there for scale.
So as you can see it'd be further than the 30mm but still not too far. The EPL 8 has a drop down screen so seeing what u're doing shouldn't be an issue.
Re distortion. 25mm is considered the 'normal' range eqv to the standard and ubiquitous 50mm on a FF camera so distortion should be minimal. Distortion tends to kick in at the shorter focal lengths.
Perspective distortion has nothing to do with focal length-it is solely controlled by camera to subject distance.  In macro photography it doesn't matter much because humans can't see that close and don't know what those things are supposed to look like. Moreover, dedicated macro lenses have very flat field curvature, or no field curvature whatsoever, so there isn't going to be any optical distortion (which is different from perspective distortion).
You can sorta test it for yourself with your kit lens. Set it to 30mm and take a portrait shot of your face.
The 30mm is really designed for extreme closeups like for scanning documents etc. It'd allow you to get uncomfortably close to the point where you wouldn't be able to see the screen. I think the 60mm is more than enough. Also since you already have the 30mm range covered by your kit lens the 60mm would give u a focal length you don't already have plus the longer focal length tends to be better for portraits etc anyway.
Here's a shot I've taken of a friends makeup with the O60 from a couple years ago.
So as you can see it really allows you to get right up in there.
Oh! The 60mm is f2.8 vs the f3.5 of the 30mm so it would also allow you to use lower ISO's for your other shots as well. Your kit lens only goes as wide as f3.5 as well so even more diversity.
The 30mm macro would be more than suitable for her purpose. The main advantage of the 60mm is a longer working distance which makes things like shooting bugs and other moving things easier. The maximum working aperture is irrelevant as she is going to be stopping down either lens to F/4 for maximum sharpness.
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
Albert Valentino Veteran Member • Posts: 9,762
one of the differences is the file type. In camera stacking creates a jpg. The number of shots that can be stacked in a lot, forget the number. The few times I used it on my EM1 I was blown away with the results and flexibility - like number of shots, space between each focus. It even has an option on how long to pause between captures to allow a flash, even third party ones like my godox, to recharge to get the same off camera lighting. It also automatically use the electronic shutter
Agreed, it is fantastic, even the size makesit fun to use.
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
Skeeterbytes Forum Pro • Posts: 23,182
75/1.8 is a fine lens, quite sharp, but hampered by a modest minimum focus distance of nearly 3 feet. It would be interesting to add an extension tube and try it with close-up work, though.
Rick
techie takes pics Senior Member • Posts: 1,730
Can't you try a lens for free? Perhaps find a local facebook group?
The 60mm seems long for a handheld shot.
Do you use the zoom a lot, when you want to get your face in? In that case the 12-40 Pro might be interesting. Wider aperture, it can focus as close as 12cm (5 inches) away, and it has roughly the same zoomrange as your current lens.
 techie takes pics's gear list:techie takes pics's gear list
Olympus PEN E-P5 Olympus OM-D E-M10 II Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +8 more
Cyvan Regular Member • Posts: 447
Re: Distortion....
I'm aware of that, but the OP made mention of taking shots of her whole face. That sounds like a headshot. At headshot range the 60mm might give a more flattering picture than the 30mm since she would be closer with the 30mm. Hence my statement.
Tedolph
I'm also aware that for what she wants to do with it the 30mm f3.5 would suffice. They both would. But if I had a choice I would want a lens that could do more than one thing. The OP already has a 14-42 f3.5-5.6. She gains nothing from the 30mm other than improved sharpness and the ability to focus more closely.
Since both lenses could work I suggested the 60mm to give her some diversity in her focal lengths. 60mm is outside her kit lens range and the f2.8 is also faster. She can therefore use it as a great portrait lens or for a little more reach and it would be better in low light than what she has now.   She gets none of that with the 30mm. In my view, if she can afford it, the 60mm gives her more options.
 Cyvan's gear list:Cyvan's gear list
Panasonic Lumix DMC-GX8 Panasonic G85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
Prairie Pal Senior Member • Posts: 2,912
Will you ever find youself photographing anything  besides make up?
Ivan
 Prairie Pal's gear list:Prairie Pal's gear list
Nikon D600 Nikon D7200 Olympus OM-D E-M10 II Olympus E-M1 III Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
Bassam Guy Veteran Member • Posts: 4,885
Didn't mean to infer that the 75 is a macro lens, just that the 60 macro is so good as a portrait lens that I stopped pursuing the 75 after I got the 60.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
FranJD New Member • Posts: 8
I've read the responses to date and there was plenty of good advice. You indicated that you hand hold the camera. I'd like to add some other info to consider. Specifically the weight and length of the lenses. If you use a tripod as some one suggested it would not make any difference.
14-42mm IIR    113gm/4.0 oz.     48.3mm/1.9 in.
30mm f3.5        128gm/4.48 oz.    57mm/2.4 in.
60mm f2.8        185gm/6.5 oz.       82 mm/3.23in.
Then there is the cost. The 60mm lens costs almost twice the 30mm lens.
