ianmt
New Member
Re: T7I and Camera Connect - Can't get it to work
Ok. I've disconnected and reconnected my 77d using the following process, so hopefully this will solve the problem.
1) Delete any camera Bluetooth connection on your phone in Bluetooth settings
2) Delete any camera WiFi connection in your phone WiFi settings
3) in canon connect click easy connection guide. If it lists any existing connections, click and hold these and say yes to delete this log.
This should have completely removed any existing connections on your phone. If you wish, you could also delete the app and reinstall it.
4) on the camera go into yellow settings menu page 1 and choose wireless communication settings
5) click Bluetooth function and then choose check/clear connection info (at this point pairing is grayed out.
6) any existing connection will be shown and the camera will try to connect. Instead click info and confirm clear connected devices
7) you should then be returned to the Bluetooth function menu and pairing should no longer be grayed out.
8) click pairing and then "do not display"
Now go back to your phone
9) open the canon connect app, click easy connection guide unless the app brings up the name of your camera having autodetected it
10) if it autodetects let it connect - the camera will also ask for confirmation
11) if it doesn't autodetect click connect a camera after going into easy connection guide (on the phone) then type in your camera model. You should then confirm Bluetooth connection on your phone . If this doesn't work, press the cross button and go back to the front menu of the app. You should find if you wait long enough in the app whilst the camera is in pairing mode, the phone will see the camera and flash up the connection window.
12) once connected, in the app, click the remote live view showing, follow the connection Windows on your phone and this should then connect you via WiFi to operate the camera from your phone.
There's no need to go into Bluetooth or WiFi settings to do the connection, just make sure they're all deleted to start with.
Good luck - hope this works!
Ian
