T7I and Camera Connect - Can't get it to work
Started Dec 22, 2020 | Discussions
seri_art
seri_art Veteran Member • Posts: 3,063
I'm trying to connect my android phone to my T7i using the Canon Camera Connect app. Everything seems fine, the phone shows the correct camera SSID, but when I try to connect to that camera network I see "Internet may not be available" and then it says the camera isn't connected (while displaying the correct SSID). Any ideas?
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
Canon EOS Rebel T7i / EOS 800D / Kiss X9i
stevet1 Senior Member • Posts: 1,300
Re: T7I and Camera Connect - Can't get it to work
Are you able to connect with any other network such as a wireless printer?
After you try to connect to your camera, do you see a little Canon icon in the top left hand corner of your wireless settings?  If you do, tap on that little icon.
Other than that, I don't have any other ideas I can offer you.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
seri_art
OP seri_art Veteran Member • Posts: 3,063
Steve Thomas
Thanks. I easily connect to my normal wifi network (it's the default network on my phone). I'll try your second suggestion a bit later.
Steve Thomas
I could be wrong, but my thinking here is that even though your are connecting the camera and the phone wirelesslely, you are not going through your router; which would be kind of cool if you are out in the field somewhere. (I personally haven't tried that yet).
Steve Thomas
seri_art
Steve Thomas
I have no idea whether this connection is supposed to go through my router, which is sitting a few feet away from where I've been trying to connect. But from a theoretical standpoint, if it did need that (or another) router to connect, then it couldn't be used in the field and I've never read of any such limitation.
seri_art
Steve Thomas
Couldn't you try it by just unplugging your router for the time it takes to do the test?
seri_art
No, didn't see that icon. I've attached images (1) from the phone showing the camera as the current network but with the warning message, (2) from the phone showing the (supposed) connection to the camera network and (3) the camera saying that it's still waiting on a connection.
seri_art wrote:
Steve Thomas
Just out of curiosity, I did just that. I turned off the router and unplugged it from the wall.
The connection went right through. The phone to camera connection doesn't go through the router.
Steve Thomas
seri_art
Which is how I'd assume ti would work. Thanks for doing that. I'm now asking over on the forum at community.usa.canon.com. If I find a fix there, I'll post it here.
ATLfromNJ New Member • Posts: 18
The connection isn't established until you open the canon camera connect software. I have never been able to establish a connection through my router, only a direct connection from camera to phone.
So turn on wifi on the camera so acts like an access point. Connect to the Canon SSID that shows up on your phone, then open the canon camera app on your phone.
 ATLfromNJ's gear list:ATLfromNJ's gear list
Canon EOS Rebel T7i
seri_art
Thanks. That's exactly what I've done. The problem is that the camera still says "Waiting to connect". I posted images of all that above. A clue might be that on page 22 of the T7i Wi-Fi manual, it says to "Select Pairing" (for establishing a Bluetooth connection), but on my camera, "Pairing" is disabled.
Try turning the Bluetooth off on your phone. See if that works. They may be getting in each other's way.
Steve Thomas
seri_art
Thanks, but got the same result. Camera still says "Waiting to connect" while phone says the Wi-Fi network is the camera SSID.
seri_art,
Sorry then. I'm out of ideas.
Steve Thomas
seri_art
stevet1 wrote:
seri_art,
Steve Thomas
Thanks for trying! I also note that no one else has chimed in with ideas, maybe because not many use that app?
ianmt New Member • Posts: 10
Have you tried clearing check/clear connection in Bluetooth connections? This should then allow you to re-pair as pairing won't be greyed out anymore?
 ianmt's gear list:ianmt's gear list
Sony RX100 III Canon EOS 77D Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM Canon EF 50mm F1.8 STM
seri_art
Please explain more about "clearing check/clear connection in Bluetooth connections".
Wireless Comm Settings
Bluetooth function
Check/clear connection info
Press info to clear settings
Press menu and pairing shouldn't be greyed out
This should allow you to pair the Bluetooth to the camera and restart.
seri_art
Bluetooth function
The only Bluetooth function I see on my phone is On or Off. However, double-tapping on "Bluetooth" then displays "Paired Devices" and in that list I see EOST7I which is the nickname for my camera. Maybe that's why "Pairing" is grayed out, because it's already paired.
Remove the Bluetooth connection in the phone and follow the camera menus listed above which will then remove the greyed out "pairing" in the camera menu.
