Sigma 70-300 APO DG or the non APO version?
Uloo
Uloo Senior Member • Posts: 2,908
Which one would you recommend?
I'm also considering the Tamron.
I'm looking for a longer lens for my K-1M2 on a low budget.
Thank you.
Ulrich
 Uloo's gear list:Uloo's gear list
Pentax K-3 Pentax K-1 II Pentax smc DA 16-45mm F4 ED AL Sigma 105mm F2.8 EX DG Macro Sigma 10-20mm F3.5 EX DC HSM +4 more
Pentax K-1
MightyMike Forum Pro • Posts: 40,886
Re: Sigma 70-300 APO DG or the non APO version?
Thank you.
Ulrich
You will want the APO version, or the Tamron, each have their issues, but thats what you get for a consumer zoom.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
Uloo
OP Uloo Senior Member • Posts: 2,908
Thank you Mike.8
Sactojim Veteran Member • Posts: 8,418
I have the non APO version and it's a ok lens. You should shop around some of the more vintage lenses with AF (auto focus) as there are a number of excellent choices and inexpensive.When home tomorrow, I'll name a few
Uloo
Thank you I appreciate your help.
alex_virt Senior Member • Posts: 2,236
Got the Tamron 70-300 recently. Very sharp from 70 to 180mm, not too bad at the long end, but very strong purple fringing in contrast areas.
Samples: https://www.flickr.com/search/?sort=date-taken-desc&safe_search=1&tags=tamron70300mmf456dild&user_id=23636245%40N03&view_all=1
The dog pic was shot at 300mm.
Emmanuel Diver Contributing Member • Posts: 607
The Tamron was my first lens I bought after my K100D. And I did get some good photos with it. The PF comes as a standard but i also tried a sigma 70-300 and found it very soft past 180. It wasn't a modern one though.
www.flickr.com/mannydee
www.pentaxphotogallery.com/emmanuelmdiver
 Emmanuel Diver's gear list:Emmanuel Diver's gear list
Pentax K-7 Pentax K-3 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sigma 105mm F2.8 EX DG Macro Sigma 24-70mm F2.8 EX DG HSM +2 more
KentG Veteran Member • Posts: 4,719
First you make sure you can't score the Holy Grail of Pentax mount Sigma lenses, the Sigma 100-300/4 EX APO IF (DG). Then you look for the other 2. And yes the APO version of the Sigma 70-300 is the better one. I always liked the Tamron one also.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 IIs Pentax K-3 II Pentax K-1 Pentax smc D-FA 50mm F2.8 Macro Pentax FA 150-450mm F4.5-5.6 +4 more
wy2lam Veteran Member • Posts: 3,321
The APO version for sure, and I'd avoid the Tamron.  I used both lenses about...12 years ago, and remember that the Tamron had a LOT of hard to correct CA.
 wy2lam's gear list:wy2lam's gear list
Fujifilm FinePix HS35EXR Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +9 more
Kent Gittings
Jesus you can't find one of those with an ouija board and a tracking dog!!
