Help with a K50 please
Started Dec 18, 2020 | Discussions
Sactojim Veteran Member • Posts: 9,105
Hello and hoping someone can help with with a just purchase (online) used, but excellent condition K50. Problem 1 is the diopter is not adjusting..at all and just a fixed out of focus view. Problem 2 is I'm not seeing the green in-focus box in the vf, but when set to LV (live view) it's there. Am I overlooking something?
I'm not new to the K50 since owning one a few years ago. I contacted Pentax/Ricoh online and it shows a estimated repair cost of $202. and possibly higher. Suggestions welcome and thank you.
Pentax K-50
PeterPentax
PeterPentax Senior Member • Posts: 1,131
Re: Help with a K50 please
Do the dioptre adjustment without a lens. Concentrate on the viewfinder grid lines being in focus. Let me know if that works.
OP Sactojim Veteran Member • Posts: 9,105
Thanks Peter. The view finder grid is not visible with or without a lens attached. When I move the adjustment bar to right or left, no change.
PeterPentax
My advice.... return the lens to the seller.
I fail to see what the viewfinder has to do with a lens? What am I missing here?
PeterPentax
I meant to say return the camera
PeterPentax
Error in my reply to OP.
labidas Junior Member • Posts: 49
You mean the RED dot in the viewfinder? It can be switched on/off. Search the menus. Focus confirmation.
Diopter might be broken. Take the camera apart or let some local repairshop evaluate it.
Don't send it to repair for an astronomical amount because the K50 is basically worth nothing. ~100$ max.
 labidas's gear list:labidas's gear list
Sony a7 III Tamron 28-75mm F2.8 III Sigma 85mm F1.4 DG GN Tamron 35-150mm F2-2.8 Di III VXD Sigma 16-28mm F2.8
Breakfastographer 2 Contributing Member • Posts: 544
Yeah, it's green in LV but red in the VF. The VF one shows up when focus is achieved. The LV one shows you in which part of the image it's trying to achieve focus.
