EOS750D/Rebel T6i - external mic not working [SOLVED]
Started Dec 18, 2020 | Discussions
StuartT50
StuartT50 Regular Member • Posts: 198
I have just upgraded from an EOS1300D to an EOS750D specifically to be able to use an external microphone for video.
The camera is recording sound fine with the in-built mic, but when I plug in the external mic (a lavalier type lapel microphone) it won't record a thing!
I know the mic works, as I've tried it with my laptop.
Any advice?
EDIT: I discovered the reason. The microphone has a TRRS plug and the camera only accepts the TRS plug (I didn't even know there was a difference!)
https://www.cablechick.com.au/blog/understanding-trrs-and-audio-jacks/
Fortunately, you can just buy a TRRS (female) to TRS (male) adapter. Problem solved.
 StuartT50's gear list:StuartT50's gear list
Canon EOS Rebel T6i Canon EF 400mm f/5.6L USM Canon EF-S 17-55mm f/2.8 IS USM Tokina AT-X Pro 11-16mm f/2.8 DX Canon EF-S 18-55mm f/3.5-5.6 IS II
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
mdmarqphoto Senior Member • Posts: 1,460
Re: EOS750D/Rebel T6i - external mic not working [SOLVED]
Any advice?
Yes, that will do it!
For future reference (and maybe for others reading this), the fact that your mic was TRRS tells us it was designed to be used with mobile phones (and some laptops).  Standard lav mics will normally be TRS (for stereo) or TS (for mono).  If you're not going to use a mic on multiple device types, it's best to buy one that matches your device - the less connections the better.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
StuartT50
OP StuartT50 Regular Member • Posts: 198
Any advice?
yes, it seems so! I assumed a jack plug was a jack plug and had no idea I was buying a mic that wouldn't work in a camera!
