Speedlight Clamp
Started Dec 17, 2020 | Discussions
topcat74
topcat74 Regular Member • Posts: 212
Speedlight Clamp
Hi all.
Made this Speedlight Clamp from a woodworkers clamp and a plastic cold shoe.
Simple but has proved very useful on location, total cost  £7.00.
 topcat74's gear list:topcat74's gear list
Nikon D850 Nikon D780 Nikon AF-S Nikkor 50mm F1.8G Nikon AF-S Nikkor 20mm f/1.8G ED Nikon AF-S 70-200mm F2.8E FL ED VR +1 more
Dannno
Dannno Senior Member • Posts: 1,642
Re: Speedlight Clamp
Looks pretty clever. How did you attach cold shoe to clamp?
 Dannno's gear list:Dannno's gear list
Canon Pixma Pro-100
topcat74
OP topcat74 Regular Member • Posts: 212
Hi Danno
I just drilled a hole in the top of the clamp, the cold shoe had a standard 1/4 whitworth thread, and screwed them together with a cap head bolt and washer.
The clamp I used has a really strong grip, and easily supports the Godox flash.
Dannno
Nice. I think I need to make one!
Canon Pixma Pro-100
RUcrAZ
RUcrAZ Veteran Member • Posts: 7,516
Great idea, I want to find a cheap, maybe used, small ball head and mount it, then use it as a camera mount as well. The advantage of the clamp is that it has spring tension, which is 'better' than  a simple clamp one tightens. The "universal" use of 1/4-20 nuts and bolts is also a convenient idea. I try to use them - instead of other sizes - whenever I can.
