NX 16-50mm @50mm Vs NX 50-150mm @50mm
Started Dec 15, 2020 | Discussions
markyboy81 Veteran Member • Posts: 4,778
Can anyone explain the differences between image quality from these?
Both same focal length at f2.8? Which would be better?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
shutterbugnx
shutterbugnx Regular Member • Posts: 168
Re: NX 16-50mm @50mm Vs NX 50-150mm @50mm
Samsung has MTF charts on their website, though they can take some digging to find. I have reproduced the relevant ones below. These are taken at infinity focus and suggest that the 16-50 would have slightly higher central sharpness but soften further towards the edges, whereas the 50-150 would have more consistent sharpness across the frame. Performance around minimum focus distance is likely rather different, I'm not sure which lens would be favored there.
S 16-50mm MTF, blue line is 30 lps
S 50-150mm MTF
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
OP markyboy81 Veteran Member • Posts: 4,778
S 50-150mm MTF
Thanks for that Shutterbug!
HenrykC
HenrykC Junior Member • Posts: 42
Ephotozine data-
https://www.ephotozine.com/article/samsung-s-16-50mm-f-2-2-8-ed-ois-lens-review-25474
16-50mm below (tested on NX30)
50-150mm below (tested on NX1)
45mm below  (tested on NX20)
Note the tests were done on different cameras so should be compared with care. But the 45mm and 50-150mm at f2.8 look a lot better than the the 16-50mm.
https://www.flickr.com/photos/101689817@N04/
shutterbugnx
HenrykC wrote:
Ephotozine data-
It appears they test at considerably less than infinity
https://www.ephotozine.com/article/lens-reviews---find-out-how-we-review-lenses-33167
EDIT: Their chart for the 45mm f/1.8 lens is really not indicative of performance across its focus range.
Imaging Resource's testing of the 3D variant shows the corners having a touch of softness when used wide-open with their own test chart. https://www.imaging-resource.com/reviews/zproducts/samsung45f18nx3d/zz_sampleindex.htm
Samsung's MTF chart shows that corners are also slightly soft at infinity. (they list the same chart for both types of the lens)
45mm f/1.8 MTF
Lastly, my (non-3D) copy is noticeably soft when used near minimum focus distance. I have provided central crops using the lens with an NX500. Final image is with Samsung's 30mm f/2 lens for comparison.
45mm f/1.8 @ f/1.8
45mm f/1.8 @ f/2.8
45mm f/1.8 @ f/4
30mm f/2 @ f/2
Sunscreen
Sunscreen Junior Member • Posts: 30
The 50-150mm @ 50mm f2.8 will have better image quality
 Sunscreen's gear list:Sunscreen's gear list
Panasonic Lumix DMC-GH2 Samsung NX500 Canon EOS R5 Sony a7 IV Canon EOS R5 C +44 more
Bixbe Junior Member • Posts: 49
Both S lenses are in action here. Gamma DR and P mode which results in depth of field necessary for street filming.
https://www.youtube.com/watch?v=7QDPlKJZC6k
 Bixbe's gear list:Bixbe's gear list
Panasonic LX100 Samsung NX1 Samsung 16-50mm F2.0-2.8
