Screen protector or not on cameras with fully articulating screens?
Started Dec 14, 2020 | Discussions
rsmithgi Senior Member • Posts: 2,939
I recently purchased an E-M5.3. Unlike my E-M1.1 and E-P5, it has a fully articulating screen. I have screen protectors on both of those cameras but have heard there may be issues with screen protector thickness when flipping the screen to the closed position.
So, for those using screen protectors with articulating screens - any issues with the screen protectors?
For those who don't use screen protectors (regardless of the screen type), do you get scratches or other wear and tear on the screen?
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus 40-150mm F2.8 Pro +5 more
Olympus E-M1 Olympus PEN E-P5
pannumon Veteran Member • Posts: 4,130
Re: Screen protector or not on cameras with fully articulating screens?
7
My cameras get scratches and other wear and tear everywhere except in the (fully) articulating screens. I have used (fully) articulating screen Micro Four Thirds cameras since 2009. I don't use protectors.
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GM1 Panasonic G85 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GF1 +21 more
lunic Regular Member • Posts: 194
Ordinary protective film is fine (and I'm using one) but tempered glass protector has an issue.
Some reported that glass protectors make swivel screen unable to be fully closed because they are thicker than ordinary film.
 lunic's gear list:lunic's gear list
Olympus E-PL7 OM-1 Leica Nocticron 42.5mm Panasonic 8-18mm F2.8-4 Panasonic Leica 25mm F1.4 II +14 more
Albert Valentino Veteran Member • Posts: 9,770
Never used them. If putting my camera ij a bag where it might get scratched I simply rotate the LCD inward leaving the hard, backside exposed. I generally use the EVF when shooting, not the LCD
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4 +10 more
Felice62 Veteran Member • Posts: 5,079
I am a bit maniac about keeping my gear free from scratches so i buy film protectots the day before i buy the camera and install them  as from first usage.
Never had an issue with screen protectors.
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Tough TG-3 Olympus Stylus Tough TG-850 iHS Panasonic ZS100 Olympus E-M5 II +36 more
Moggi1964
Moggi1964 Regular Member • Posts: 448
I use one on my EM1 MkII. It raises the screen about 1mm when folded away which I have not found to be an issue.
I put them on my phone so figured why not on the camera. May not need one of course but it isn't doing any harm as far as I can tell.
 Moggi1964's gear list:Moggi1964's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +5 more
mikero
mikero Veteran Member • Posts: 3,057
I've never even thought of using a protector, and never had much of a problem.
Mike
 mikero's gear list:mikero's gear list
Olympus E-M1 II OM-1 Olympus 45mm F1.2 Pro Olympus 8mm F1.8 Fisheye Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
I wouldn't if they hurt the camera or my phone screen.
They call them protectors for a reason, afterall..
jeffharris
jeffharris Forum Pro • Posts: 11,411
I've always used one with my fully articulated screen cameras; GH2 and GX8. No issues at all.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
puttin
puttin Veteran Member • Posts: 7,958
I use a thin one on my G9
 puttin's gear list:puttin's gear list
Nikon Coolpix A Canon G9 X II Panasonic Lumix DC-G9 Panasonic Lumix DC-S5 Sony a7 II +25 more
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
I think it depends on how you use and store your camera.  I always store with the screen facing inward and for both G80 and G9, often just use the EVF, including for the odd shot review.  So, I never use a screen protector with a fully articulating screen.
I have used protectors, without issue, other than the odd bubble, on my fixed screen Compacts and touchscreen M43 - GM1/GM5/GF7 .
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-LX7 Panasonic G85 Panasonic Lumix DMC-GF7 Panasonic Lumix DMC-GM1 +13 more
Tapper123
Tapper123 Senior Member • Posts: 1,934
5
About 6 years ago I bought a 2 pack of film screen protectors for my EM5 II, and yesterday applied my extra one to my new EM1 III. Fit perfectly, and I have zero bubbles or anything like that (I'm pretty experienced at applying screen protectors). Beware of glass ones because they are thicker and may not allow the screen to fully close facing inwards.
As for needing one or not - yeah, why not use one? They're cheap enough, and I've seen people remark about getting scratches on the LCD and not even knowing how they happened. I know some don't worry about the condition of their cameras, but I like to keep mine in pristine condition if I can - it's a hobby and these things are expensive, and "like new" cameras have better resale value.
 Tapper123's gear list:Tapper123's gear list
Sony RX100 III Sony Alpha NEX-F3 Olympus E-M5 II Olympus E-M1 III Olympus 12-40mm F2.8 Pro +7 more
joeletx Veteran Member • Posts: 4,127
I have never used screen protectors since the E-500, that was 12 years ago. I have never used one on my smartphone either. All device screens are made with high tempered glasses that can resist scratches against many clothes or household items. Dragging the screen across the concrete floor or rock will definitely does harms to the screen but what is the chance of this happens?
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +10 more
Woody S
Woody S Contributing Member • Posts: 751
I usually keep the screen turned inward because I prefer/need to use the EVF. The only time the screen is turned outward is when it's need to take a photo. With my old eyes I can't really focus on the LCD without my trifocals and I can't wear them when walking in forest and field.
drmarkf Contributing Member • Posts: 951
Back in the day when I added an original Sony RX100 to my Olympus gear, the first time I took it out I carried it in my jeans pocket and scratched it on one of the rivets. Since then I’ve always used a screen protector on all my cameras.
It must be said that Sonys had a bad reputation for scratchable screens and I’m sure modern bodies from all manufacturers are a lot better now, but I’ve never had an issue from the protectors and why take the risk?
 drmarkf's gear list:drmarkf's gear list
Fujifilm X70 Olympus OM-D E-M10 II Sony a7S Olympus E-M1 III Olympus E-M5 III +17 more
Scratching the rest LCD weather fully articulated or tiltable is something I have never experienced a d wish I'll never do.
I just can't stand it.
Reason why b'efore even getting the camera i buy its screen protector.
Ranlee Senior Member • Posts: 2,262
Phone yes, cameras no
My phone gets banged and dropped a lot so it does have a protector (the original from Samsung - not glass but plastic I believe.  Still looks good after a couple years.
Cameras - I used to with point a shoots but haven't on any Panasonics starting with the GX7, GX8 and now with G9's.  I don't bother turning in the screens either when I slide them into the bag.  Not a scratch on any of those screens after years of use - well, I haven't had the GX7 for quite some time so who knows about it.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-S5II Panasonic Leica 200mm F2.8 +10 more
Old Timer63
Old Timer63 Veteran Member • Posts: 6,018
I always fit the clear plastic protectors , I order them as I order a new camera ( why not, they don`t affect IQ) if you wear tops with zips etc you can gradually damage the screen and there is no doubt about it you get a better price when you sell inc keeping the original box and paperwork.
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Fujifilm XF 14mm F2.8 R Panasonic Leica Summilux DG 25mm F1.4 Fujifilm X-T10 Panasonic Lumix DMC-G7 +20 more
cc99 Contributing Member • Posts: 565
Re: Screen protector or not with/out viewfinder
My Oly E-PL7 (with no built-in viewfinder) needs a screen protector, because if I place it on its back, the screen glass will be in full contact with the underlying surface, and can easily scratch (eg, if sand is present).
My E-M1.2 and 1.3 don't have the same problem, because their protruding (built-in) viewfinders always keeps the screen away from any surface I lay the camera on.
 cc99's gear list:cc99's gear list
Olympus E-M1 II Olympus E-PL7 Olympus PEN-F Olympus E-M1 III OM-1 +28 more
trvlfool Junior Member • Posts: 46
I use a protector and never close the screen. The screen doesn't seal fully with the protector if I were to try, but honestly, I fear breaking the hinge by inadvertently twisting it too hard, perhaps in the wrong direction. My inner self believes the phrase "If it jams, force it. If it breaks, it needed replacing anyway." Unwise, but there it is.
 trvlfool's gear list:trvlfool's gear list
Olympus E-M5 III OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS +1 more
