G12 Lens
Started Dec 13, 2020 | Questions
rainydiary Regular Member • Posts: 429
G12 Lens
Hi all
I have G12 and I like the zoom lens. I plan upgrade to full frame and looking for similiar zoom lens.
In below review said lens of G12 similiar to 28-13 5mm in full frame.
Does it correct ?
https://www.kenrockwell.com/canon/compacts/g12.htm
Thank
Canon PowerShot G12
Max@Home
Max@Home Veteran Member • Posts: 3,771
Re: G12 Lens
rainydiary wrote:
Hi all
In below review said lens of G12 similiar to 28-135mm in full frame.
Does it correct ?
Thank
It is not correct, (but almost ) the G12 has a 28mm - 140mm equivalent lens
https://www.dpreview.com/products/canon/compacts/canon_g12
The closest you can get with an EF lens for fullFrame is the (discontinued) EF 28-135 IS lens, which is a very old design (was the second lens with IS in the Canon invertory, once).
the newr versions you might want to look at are EF 24-105 offerings which come in a fixed aperture F4L(version II) IS USM or a variable aperture F3.5-F5.6 IS STM version.
...€0.02...
Max@Home
Max@Home - Castricum - The Netherlands (see profile for equipment)
www.pbase.com/max_at_home (mind you, use underscores!)
 Max@Home's gear list:Max@Home's gear list
Canon PowerShot G3 Canon PowerShot Pro1 Canon G1 X II Canon G3 X Canon EOS 20D +11 more
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: G12 Lens
I don't have the G12 but the G16 ......
You may want to pick up an SD880 or a baby M camera with the lens - very compact and interchangeable lensĀ
rainydiary wrote:
Hi all
Does it correct ?
Thank
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
Guillermo Shashte Senior Member • Posts: 1,011
Re: G12 Lens
Does it correct ?
Not really, I was looking at the specs of the G16 lens: 6.1 to 30.5mm. That is:
6.1 (W) - 30.5 (T) mm (35mm film equivalent: 28-140mm)
While the lens is equivalent to 28-140mm, optically it is still a very wide lens. Wide lenses are good when you need greater depth of field at lower f stops (i.e. f.18-2.0).
You will soon notice that your DSLR pics don't look that sharp due to limited depth of field because a 28-135mm DSLR at 28mm will have a depth of field about the same as your G12 zoomed all the way.
Another difference is the focusing distance:
DSLR 28-135mm lens: 0.5m / 1.6 ft
G16 6.1-30.5mm lens: Normal: 2.0 in. (5cm) - infinity (W), 1.3 ft. (40cm) - infinity (T)
GS
Re: G12 Lens
Guillermo Shashte wrote:
Does it correct ?
Compare these two pics:
Camera Model: Canon EOS D60 (APS camera -1.6 crop factor)
Shutter speed: 1/125 sec
Aperture: 8
Exposure mode: Manual
ISO: 100
Lens: 100mm
Focal length: 100mm
Subject distance: 0.505 m
AF mode: One-shot AF
Focus point: [Center]
Camera Model: Canon PowerShot G2
Shutter speed: 1/30 sec
Aperture: 2.2
Focal length: 14.6mm
GS
