Wireless flash trigger + Flash lights for nx1, nx500
Started Dec 12, 2020 | Discussions
ken69 Junior Member • Posts: 25
Anybody used youngnuo or godos flash lights with nx1/nx500? What wiresless flash triggers do you use, suggest?
I am thinking about godox ad200 for outdoor (often in strong sun) and indorr product photography
Samsung NX1 Samsung NX500
Peter Her Junior Member • Posts: 28
Re: Wireless flash trigger + Flash lights for nx1, nx500
Hi, I'm also interessed by this one. I have an ad200 pro that I use for my other gear (Lumix G9). But i have no idea how to trigger it with my NX1...
OP ken69 Junior Member • Posts: 25
i bought 2x ad200 pro... will buy wireless trigger soon so i will answer soon...
As i know it works very well but in manual mode.
PETCO New Member • Posts: 10
Hi  I use the Godox xt 16 to trigger my AD200.
Not recommended in bright sun light. Because...
There is no HSS available on any other system than the Samsung flash..
You can trigger HSS with optical flash.
But it only works in low light situations. Or indoors.
You can of course use an nd filter so you don't blow out your highlights, in bright sunlight.   Or put your AD200 closer to the subject, or use 2 AD200 as it requires more power from you'r  flash.
your max sync on the NX1 is 1/250  and the NX500 is 1/200.
If you try to use a faster sync speed. The flash will not be triggered..
 PETCO's gear list:PETCO's gear list
Samsung NX1
yes, i will use nd filters... don't know yet what are good and what i need but i will learn and buy soon nd filters
Sunscreen
Sunscreen Junior Member • Posts: 30
I highly suggest the Heliopan Variable ND 0.3 - 1.8 https://www.adorama.com/hp72vnd.html?CategoryID=244555 and Hoya UV & IR cut combo https://hoyafilter.com/product/uv_ir_cut/
There's cheaper options out there, but this has been my go to for 5+ years on numerous systems.
Hope that helps!  Happy shooting!
 Sunscreen's gear list:Sunscreen's gear list
Panasonic Lumix DMC-GH2 Samsung NX500 Canon EOS R5 Sony a7 IV Canon EOS R5 C +44 more
