RSColo
Leica 90mm f/4 Macro Lens and Macro Adapter M Questions
Dec 12, 2020
The 90mm f/4 Macro is a collapsible lens. In its collapsed state, any resulting photos are totally blurry. The lens needs to be extended in order to function normally. Leica has also made an adapter for the lens which is basically an adjustable close-up ring. The adapter attaches between the lens and the camera. It then extends from 18mm to 30mm by turning a ring. Note that with the adapter either live-view or the Visoflex needs to be used as the combination does not link with an M camera’s rangefinder. The adapter can also be used with other M lenses for close-up shots. But uniquely it can allow the 90mm lens to stay collapsed and still focus throughout the lens normal focus range all the way to infinity. But here things get complicated.
Let’s start with a look at the cut-away diagram of the lens and its elements:
In this view of the lens extended, there are three elements that extend out and one that remains behind. This allows the lens, without the adapter, to operate normally. If the lens is collapsed and attached to the camera with the adapter in between and set to 18mm the lens will also operate normally. But these two configuration are different. In one case three elements are extended out by considerably more than 18mm. In the other all four elements are kept together and extended only 18mm. How can both of these situations result in the lens operating “normally”? Is there any difference in optical quality? They are both supposed to result in infinity focus, but is the closest focus different?
Now let’s explore the question of close-up photography. I am using the term “close-up” instead of macro because the latter term is supposed to refer only to images that are 1:1 or more. I am interested in the case of the 90mm lens attached to the camera with the adapter in between. The photographer has two choices: extend the lens or dial out the adapter. What happens in each case? Is one sharper than the other? Can the lens be used in any configuration other than fully collapsed or fully extended? Finally, what happens if both are extended?
I have searched on the Internet and found very little answers to any of these questions. I only own the lens and can only partly answer one of the questions. The lens can be extended anywhere between collapsed and fully extended, but only locks into place at one end or the other. Without the adapter the lens is only usable in the fully extended mode. So anything less with only my lens is just not of any use. I am considering getting the adapter, but it is very expensive for what it is (over $700 and contains no Leica glass). Has anyone out there had any experience with this lens/adapter combination? If so, can you answer any of my questions? Thank you.
Reid Shay
www.sawatchpub.com
Colorado, USA
