Anybody has nx1 service manual? Problem with dials
Started Dec 10, 2020 | Discussions
Ananiash
Ananiash New Member • Posts: 6
Re: Anybody has nx1 service manual? Problem with dials
PM sent. Thank you.
 Ananiash's gear list:Ananiash's gear list
Sigma DP1 Sigma DP2s Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon D3 +6 more
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
Ananiash wrote:
PM sent. Thank you.
NX1 Service Manual sent (along with other NX Manuals you may find useful)
Best regards,
Lawrence Norman
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
CyberDEL
CyberDEL Regular Member • Posts: 234
That's very kind of you Lawrence, thanks.
By the way does anyone have the service manual of NX500? Just in case...
Dimitri D
https://www.flickr.com/photos/135820506@N02/ My Flickr Photostream
 CyberDEL's gear list:CyberDEL's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 20mm F2.8 Pancake Samsung NX 85mm F1.4 ED SSA +21 more
Ananiash
Greetings from Ireland,
I don't have it unfortunately but it is pretty straight forward to dissassemble. In general ifixit would  cover this part in full. What would be nice to have is some file repository just like the xda forum, to have them all in one place. And also thread to cover if things go south.
I'm digging through the net to find file to boot my camera in download mode but I can't find it..
NXfiles
NXfiles New Member • Posts: 6
I am also interested in the service manuals. I found quite some on https://www.nodevice.com/service-manuals/vendor/samsung (NX10, NX200, NX300, NX1000, mini) but I want to make a mirror of all NX material for next generations of NX fans.
 NXfiles's gear list:NXfiles's gear list
Samsung NX mini Samsung NX1 Samsung NX500
Lawrence Norman
Happy to help; send me a PM with your email address
Lawrence Norman
Thanks for the PM; : just sent you a link to a zipped file that contains EVERYTHING I have:
Samsung Documents
1. NX1 Service Manual.pdf
2. NX1 User Manual.pdf
3. Flash SEF580A User Manual.pdf
4. NX500 User Manual.pdf
Samsung Executable Programs
1. Remote Studio
2. DNG Converter
3. Movie Converter
Thank you very much for your Web Site.
Lawrence
Tigerventer New Member • Posts: 3
Hi all
My NX1 died. Last had it plugged into my computer. Left it plugged in and switch off computer.  I am after the NX1 service manual if anyone can help please
Johan
NXfiles
You can get it from https://nxfiles.nx.tc/files/NX1/Service-Manual/
Before disassembling, I suggest plugging it into a USB power supply with the power switch turned off or charging the battery in an external charger, and to try it again afterwards. Maybe it is just dead battery.
Archivist of Samsung NX files: https://nxfiles.nx.tc/
sChMiRiC
sChMiRiC New Member • Posts: 3
Hy Nxfiles
can you pm me?
i have a service manual for you
 sChMiRiC's gear list:sChMiRiC's gear list
Sony Cyber-shot DSC-F828 Samsung TL500 Panasonic Lumix DC-TS7 Nikon Coolpix P1000 Panasonic LX100 II +12 more
Thank you so much NXFILES
Very comprehensive manual. Thanks for the advice also. It seems not to be the Battery. I will poke around and do some measurements then report back if I find the problem. I am a current Avionics engineer at a major airline and have 50 years of hands on experience in electronics. I have the confidence in digging deeper and needed the manual. Pity  the schematics are not included. That would be so much easier then.  Real pity SAMSUNG pulled the plug on this one. The NX1 was so much more than the Panasonic GH at the time and I bought all the lenses also made awesome 4K video of my daughters wedding etc. Really a big investment wort saving if possible.
ge0rg Forum Member • Posts: 51
I've scrolled through the NX1 manual after disassembling a few NX500s (IR modification, sensor replacement), and it is astonishing how many internal parts and PCBs the NX1 has compared to the NX500. I'm still not sure if this is required by the design or was just a series of shortcuts to bring it to market ASAP.
 ge0rg's gear list:ge0rg's gear list
Samsung NX300 Samsung NX mini Samsung NX500
Ananiash
Disassembling NX1 is easy, at least if you want just to pull out the mainboard for testing. Only concerning thing for me was how fragile the flex cables are. They sit in fairly tight but to reduce the strain when pulling, most of them have hole for extra grip where you can help yourself with tweezers. I wouldn’t touch the sensor screws as they are holding the sensor parallel to the lens mount.
My other NX1 has dead motherboard. Out of curiosity I’ve shorted ground with one of the testpoints. The autofocus light started to blink but I’ve freaked out and stopped. Maybe this  could give a clue.. I have flashed bricked android boxes by shorting some nand pins ( enabling download mode ) so this where I got the idea from
This is also documented in the service manual under section "7-6 Main PCB Recovery". If the round pair of pins on the board is shorted, the bootloader of the camera will expect two files, "downloader.bin" and "nx1.bin" on the SD card.
I've done a small bit of reverse-engineering of the bootloader in https://github.com/ottokiksmaler/nx500_nx1_modding/issues/121 but my ARM skills aren't that great. The missing part is the "downloader.bin", I assume this is code that will initialize the hardware, read the "vImage" partition from "nx1.bin" (that contains a linux kernel and firmware flasher) and start it. Samsung never provided these files, and writing them from scratch will be unbelievably hard without any documentation of the SoC.
The second-best option is probably to reverse engineer the first stage bootloader enough to understand the required downloader.bin format, then to reverse engineer the second state bootloader enough to be able to copy hardware initialization code, then to write a bootstrap loader for that. Sounds like a few weeks worth of work for somebody who is versed in ARM disassembly (which I'm not).
Edit: or to get somebody from Samsung or a Samsung affiliated repair shop to leak those files.
Ananiash
Hi Georg,
Absolutely. This would  be difficult as hell but on the other instance, I believe that there should be window of possibility to connect the camera under linux terminal just like adb protocol in android phones and sideload the firmware. I also was trying to contact samsung but they flushed my request as well as I was trying to get in touch with chinese repair centres and vendors from aliexpress to see if they can help but they asked me if I can bring my camera to the repair shop lol. On the bottom of the nx1 service manual there are samsung server addresses and I think this could be our source for files but on the other hand I can't imagine that for all those years no one who had access, wouldn't leak it.
BTW Georg, thanks again for the nx500
The NX3000 / NX mini SoC has a special boot modewhere it will register as a "special" USB device, but there is no protocol documentation for that. I very much doubt that NX1/NX500 have something similar. There is probably a serial port somewhere, but I don't think that it goes through USB either, and you can't flash 350MB through serial anyway
Those go to the GSPN (Global Service Partner Network), so I assume any licensed Samsung repair shop will have access. Maybe Tigerventercan bring the broken NX1 into a repair shop, have a nice chat about electronics and avionics repair and convince them to accidentally drop an SD card with "downloader.bin"?
Lucy P Junior Member • Posts: 29
Would very much appreciate the manual info also.  I am a long time NX1 user and use the camera in my work.. Please send to Shop4ax@Q.com.
Thanks much,
Lucy
 Lucy P's gear list:Lucy P's gear list
Canon PowerShot A710 IS Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung NX 45mm F1.8 +3 more
CyberDEL
Dimitri D
If anyone have the service manual of NX500 and want to share it with us, this is mine/ours last chance here in DPREVIEW while it's closing permanently. Thank you.
Dimitri D
Jay Kelbley
Jay Kelbley Contributing Member • Posts: 585
NXfiles!
Thank you so much for archiving all this, and making it available!
You are awesome!
____________________
Jay Kelbley
 Jay Kelbley's gear list:Jay Kelbley's gear list
Kodak LS420 Samsung EX2F Samsung Galaxy Camera (Wi-Fi) Canon EOS D30 Kodak DCS720x +25 more
2reE New Member • Posts: 1
Hi, please provide NX1 service manual before site closes down.
email: tore@eideutvikling.no
 2reE's gear list:2reE's gear list
Samsung NX1
