Anybody has nx1 service manual? Problem with dials
Started Dec 10, 2020 | Discussions
ken69 Junior Member • Posts: 25
Anybody has service manual for Samsung nx1?
I'd like to try to fix problem with dials... i need to use a little "force" to change from M to A... etc (2 upper dials doesn't work very well)
Samsung NX1
White Widow Forum Member • Posts: 66
Re: Anybody has nx1 service manual? Problem with dials
Hi Ken,
since nobody is answering you, I'll chime in here... I don't know where you could get a service manual. But problems with the dials are a common Samsung NX issue for all cameras. There are a couple videos on youtube describing how to clean it:
https://www.youtube.com/watch?v=4iwaVkSvkdo
If you search the forum you will find this was discussed here as well. There were different approaches. Contact spray seems to work, at least temporarily.
Luckily I haven't encountered this issue on my own cameras yet. But I hope you can get it sorted out.
 White Widow's gear list:White Widow's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +4 more
OP ken69 Junior Member • Posts: 25
Thanks for link...
I read some post here but nothing detailed about nx1...
Anybody tried method from this link for nx1? I am a little worry not to damage camera because i need it
Usually when i read, saw youtube videos... people first remove parts and then clean - first time i see without it and clean camera as is... Thanks for video
markyboy81 Veteran Member • Posts: 4,778
ken69 wrote:
Thanks for link...
I've tried this with my NX1 and it works, but only temporarily. The dials that have some issues for me are the dial on top that controls aperture/shutter speed and the drive dial. They both work to an extent anyway but the spray does help. I didn't take the battery out first though..
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
ArendjeF Junior Member • Posts: 28
LS,
You can also replace the top cover with a new one, take a look at eBay, this one for example:
https://www.ebay.com/itm/95-NEW-Samsung-NX1-Top-Cover-Shell-Case-With-Button-Flex-Cable-/264940591899
ArendjeF wrote:
LS,
good tip! I wonder what '95% new' means?
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
NX1 Top Cover Shell Case Frame with Flash Dial Button Flex Cable
markyboy81 wrote:
ArendjeF wrote:
LS,
Good question for the $119.99 with advertised, "Condition Used 95% new".
Different eBay link: "Condition: Open box “95% NEW”
https://www.ebay.com/itm/For-Samsung-NX-NX1-Top-Cover-Shell-Case-Frame-with-Flash-Dial-Button-Flex-Cable/264780824049?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3Dd95234af07e14541b93c67fbe72583a4%26pid%3D101224%26rk%3D1%26rkt%3D5%26mehot%3Dnone%26sd%3D264940591899%26itm%3D264780824049%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic%26brand%3DUnbranded&_trksid=p2047675.c101224.m-1
$119.99 for advertised "Condition Used 95% new"
$127.99 for advertised "Condition Open box 95% NEW"
[$8 dollar diff]
Ask Open box seller if [any] instructions in open box.
Yes instructions: $8.00 well spent [real bargain if detailed instructions]
No Instructions: ouch, very expensive box.
"If you don't read the newspaper, you're uninformed. If you read the newspaper, you're misinformed." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
Aadjuh New Member • Posts: 17
you have an mail adress?
i will share the manual with you
 Aadjuh's gear list:Aadjuh's gear list
Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED Samsung 16-50mm F2.0-2.8
I have.
So if you still want it , let me know.
Lawrence Norman
Aadjuh wrote:
I have.
Great
I'll send you a PM.
VERY much appreciated
Lawrence Norman
Aadjuh wrote:
I have.
Thanks for the Service Manual Aadjuh
Piet22 New Member • Posts: 24
Hello Aadjuh and TuVuVu,
As I have problems with my NX1 I would also very much like to have the service manual.
Could you please help me out?
Thanks,
Piet
Lawrence Norman
Thanks,
Piet
Yes, and shared using your p*@z*.nl email account (per your previous PM).
“What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so." -Mark Twain
Thanks, but you did send remote studio instead of the service manual. Could you please send the service manual? Many thanks!
adamaswow New Member • Posts: 3
Hello?
I am an nx1 user. My Bluetooth of nx1 is not working. I would like to request that you provide a service manual in this article. Can you provide me with the nx1 service manual?
adamaswow wrote:
Hello?
Hi there,
stil need it ?
or did anyone already provide it to you.
Hi there,
I need an nx1 service manual.
I want you to re-provide me the nx1 service manual through e-mail. My email is (prototype1@naver.com). and if you have a dnloader.bin file for nx1, please send it with the service manual. This is to try to recover the pcb.
Thanks a lot. ^^
adamaswow wrote:
Hi there,
Thanks a lot. ^^
I did send you a mail.
Ananiash
Ananiash New Member • Posts: 6
Hi guys, if anybody could share the manual it would be great. I'm stuck on firmware update error with no access to the camera menu. Thanks in advance.
Filip
 Ananiash's gear list:Ananiash's gear list
Sigma DP1 Sigma DP2s Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon D3 +6 more
Lawrence Norman
Filip
I have a copy; please provide your email address.
