If You Get A Good Copy It's AMAZING Locked
Started Dec 9, 2020 | User reviews
This thread is locked.
ProDude Senior Member • Posts: 4,851
I never thought I'd be saying this about a "superzoom" lens having had my share of them over these last 20+ years. I ordered one for walk around purposes and was rather quickly disappointed. It was pretty sharp in the middle but had odd bokeh and was a tad soft on one side. I sent it back and thought rather then give up on first try check out a 2nd copy. Man oh man this 2nd copy blew me away. I instinctively assumed this would not be much better than the 1st, but it was like an entirely different model. Not only was this copy sharp as a tack across at least 2/3rd of the image side to side at 240mm (quite unusual actually when you are zoomed out all the way on any zoom) but the bokeh isn't shabby in the least. Not the busy rough stuff I saw before.
The CA with in camera processing is quite GONE and it was also the same result processing a RAW file through the new DXO Ver. 4 that just came out. That program has the profiles for the Canon lenses down pat. The color rendition is Canon all the way NO compromises as I'd expected. Contrast is way higher then it has a right to be at this price point Focus is instant and ironically EVEN inside the house with less then decent light, which once again this lens was NOT intended for.
The largest single surprise was at wide 24mm right through at least 100mm when stopped down, this lens can literally pass the grade for landscape. The micro contrast is simply stunning and I'm still shaking my head how the heck they could do this for the price. But once again I can't help but wonder if all copies are or should be this great or if I just was blessed with a perfectly centered copy. Who knows. In the end there is quite frankly NOTHING to criticize on this lens, other than my having to shell out $38 for a freaking lens hood. I find the build quality extremely good with NO play whatsoever and no movement in the extending part of the lens shafts. What else can I say, it's amazing. Here's an landscape shot taken with it that I think speaks for itself.
Name the gear and I've probably owned it and used it.
Canon RF 24-240mm F4-6.3 IS USM
Canon RF
Announced: Feb 14, 2019
ProDude's score
5.0
Average community score
4.4
J A C S
J A C S Forum Pro • Posts: 20,521
Re: If You Get A Good Copy It's AMAZING
It looks like there was some serious processing done.
OP ProDude Senior Member • Posts: 4,851
Not really. Just the DXO 4 profile was applied with it's default sharpening. I was impressed nevertheless. Remember this is no "L" lens but still does a fine job.....especially if your traveling
shawnphoto Senior Member • Posts: 1,307
Looks like the kind of artifacts associated with Topaz AI products... Interesting!
Biden will save us!
 shawnphoto's gear list:shawnphoto's gear list
Canon EOS R Canon EOS RP Canon EOS R5 Canon EF 24-105mm F4L IS II USM Canon RF 28-70mm F2L USM +4 more
First let me be absolutely clear (not that you aren't aware of it). If you take a absolutely pristine file, and upload it to this site, one thing is for sure. it will NOT be pristine any longer. The compression or whatever is going on can easily add some artifacts. I've been on this site since 2000 and it's never been any different. I can only tell you if you're seeing artifacts it's NOT the file it's the results of the process uploaded to this site. As for reminding you of Topaz...............puhleez. The DXO process is without a doubt superior. I've worked with the Topaz stuff and as interesting as it is. It doesn't deliver like DXO will.
poppyjk
poppyjk Senior Member • Posts: 1,167
EXIF shows that this photo was taken at 34mm and not 24mm.
Would be interested in seeing a 24mm given the reported distortion issues at 24-26mm.
"Well done is better than well said" - Benjamin Franklin
You have my express consent to edit any of my images that I post on DPR.
 poppyjk's gear list:poppyjk's gear list
Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 35mm F1.4L II USM Canon RF 24-105mm F4L IS USM +5 more
Karl_Guttag Senior Member • Posts: 1,884
Basically, the 24-240 was designed assuming correction so you will not see distortion unless it is opened in say Adobe RAW with no correction deliberately (as far as I know there is no option to not corrected it with Canon's DPP4).
The digital corrections do a great job of preserving contrast. What you end up losing, unlike a "conventional lens" is resolution. At the outer parts of the image, the elements of the image are crammed together so to speak. As the distortion correction resamples/scales the image, you A) have lost the resolution and B) there are additional losses in the scaling process (good old Nyquist sampling issues). All this said modern software seems to do a good job.
Because there is a resolution loss and not simply due to focusing softness, past a certain point you can't improve the corners with a higher f-number like you would with a "conventional lens. You do gain a little by stopping down but not as much as you would with an old lens. You quickly reach a point where the sharpness is limited by the resampling.
I would be curious to see a study on the effect of using a lower and higher resolution camera with this lens. In theory, with a higher resolution sensor, stopping down would give more of an advantage.
I did a little comparison myself about 1 month back with a Canon RP, I should add that the test pattern was about 2/3rds of a meter wide so at 24mm it was from pretty close range:
https://www.dpreview.com/forums/post/64556610?image=1
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
BlueRay2 Forum Pro • Posts: 14,816
edges and CA look horrendous! it has characteristics of a typical ef-s lens.
Absence of evidence is not evidence of absence!
davidwien Contributing Member • Posts: 572
ProDude wrote:
... let me be absolutely clear (not that you aren't aware of it). If you take a absolutely pristine file, and upload it to this site, one thing is for sure. it will NOT be pristine any longer. The compression or whatever is going on can easily add some artifacts. I've been on this site since 2000 and it's never been any different. I can only tell you if you're seeing artifacts it's NOT the file it's the results of the process uploaded to this site.
I am not surprised to read this; but I do wonder why, when so many members upload files to show their technical quality, the management of the site doesnt provide a more transparent display. Otherwise, making comparisons is a bit of a bad joke!
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
JustUs7 Senior Member • Posts: 4,327
24mm (I believe) through a 10 stop ND, finished in DPP4. Transferred to the phone and uploaded here.  Don’t know how pure that leaves it.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
looks good except for that big log at the bottom, i find it distracting
tkbslc Forum Pro • Posts: 17,522
I think AMAZING is a bit of an exaggeration.  If we use AMAZING in all caps for the 24-240, what do we call the 28-70 f2 or 50L?
A couple more A’s, Z’s, and a string of G’s at the end.
I like the 24-240, but let's be honest.  It's a slow, utilitarian lens.  It's like a minivan.  Very useful to a lot of people, but nobody I have met is excited to drive one.    OP needs to let his confirmation bias settle a bit before he starts throwing out superlatives like AMAZING.
I think most 24-240 users who are honest would say things like "it's one of the better superzoom lenses I've used" or "it's pretty good".   No caps needed.
I’m going to hike 9 miles round trip up 2,200 ft on the way out and drag that log out of the way and try again. 👍
SonyX
SonyX Senior Member • Posts: 1,238
I'm afraid, there is no 24mm ...
one of the samples from DPR gallery converted with RT
 SonyX's gear list:SonyX's gear list
Nikon D4 Sony a7R II Panasonic Lumix DC-G9 Sony a7 III Nikon AF-S Nikkor 24-70mm f/2.8G ED +10 more
Hand Held?
You could have sold a lot of lenses if you said you had handheld it😊. I was wondering but then I check the shutter speed and it was 30 seconds so I guess not.
I have been impressed so far with the IS on the 24-240, but it is not up to 30 seconds at 24mm. It does seem to live up to about 4 to 5 stops (YMMV based on how picky and how good you are).  At least without stacking photos at a higher shutter speed.
J A C S
It could still be 24mm after cropping and correcting the distortion.
Re: Hand Held?
Bulb mode. 52 seconds I think. Dpreview defaults to 30 when bulb mode is used. IS was off.
I mean, I have a very steady hand.
It’s been well established that the field of view is closer to 22 mm at the wide end with corrections bringing it to an actual 24. And somehow the software engineers do this without losing any pixel count in the exif.  IDK. Outside of my pay grade.
