Olympus EM10 MK-II LCD Screen Off Cause off EVF
Started Dec 6, 2020 | Questions
roastandstreet New Member • Posts: 2
Hi Guys,
I have some issue with my camera,the issue is my lcd screen off like when your eye or object near the evf sensor. At first the screen off when I tilt the LCD, now when I turn on the camera the screen became off. Now it got reverse, get back to on when I tilt a litte bit. Any idea what the cause is?
Or maybe I should go to service center?
Olympus OM-D E-M10 II
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
Re: Olympus EM10 MK-II LCD Screen Off Cause off EVF
Does it switch to the EVF when the screen turns off?
Could be some sort of eye-sensor failure. But first, check your EVF setting in the menu...
Push the button on the right of the EVF hump - if pressing that switches from screen to EVF and back, then you have perhaps Custom Menu - J (Built-in EVF) - EVF Auto Switch set to off?
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
OP roastandstreet New Member • Posts: 2
Yes,it switch to the EVF
Already switch EVF auto mode to off,screen still off.
If its cause by eye-sensor failure, do I need replacement of the eye-sensor?
Lichtspiel
Not sure if it is worth the cost to fix it. I recently bought a new 10ii with kit lens for $300. I guess it would not hurt to ask.
Seems like a number of these are failing, with different symptoms. My old 10ii tends to favor the EVF, but I can still switch manually so that will work until it totally fails.
dlevitt Senior Member • Posts: 1,188
Hi Guys,
I have this problem too - the likely culprit is the ribbon cable connecting the display to the rest of the camera.
On mine, the touchscreen functions still work [like 'nose controlled' focus points] even with the screen dark. The screen does not light when flat, but will work at a few tilt angles.
When I checked the cost of repairs - I discovered that Olympus 'flat rate' repairs were priced higher than a refurb body [when the refurbs are available].
Since the camera is still mostly functional, I decided to live with it. I did do a substantial upgrade this year, adding a M1.2 body and and the 12-200 travel zoom lens.
Save the Earth! Collect the entire set!
 dlevitt's gear list:dlevitt's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-LX7 Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
