X-E3 LEDs causing LCD & EVF flickering
Started Dec 5, 2020 | Discussions
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
I’ve done some searching but other’s experience with this only seems to be related to using face detect and DR400, or initial firmware versions.
My XE3 performs perfectly with the exception of when the sensor is exposed to LED lighting.
I am using mechanical shutter only, not using face/eye detect. Am using DR100 (tried all). Firmware is latest v1.30. I’ve done complete resets. I’ve tried various ISO, SS and aperture values as well as a few different lenses.
The flickering is severe. Not present with incandescent, CFD’s or fluorescent lights. My X100V and X-T2 do not have this issue.
Again, the camera works great otherwise. Anyone else experiencing this behavior with their XT3?
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
Fujifilm X-E3 Fujifilm X-T2 Fujifilm X-T3
Miguel-C
Miguel-C Senior Member • Posts: 2,321
Re: X-E3 LEDs causing LCD & EVF flickering
It's a documented issue of the Xe3, can you send it back or get it replaced?
Cordial Regards
 Miguel-C's gear list:Miguel-C's gear list
Fujifilm X-T2 Canon EOS M5 Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Fujifilm XF 35mm F2 R WR +3 more
Robmas4229
OP Robmas4229 Senior Member • Posts: 1,272
Thanks for the reply.
The only things I found documented was when using the camera (with early firmware) with face detect and DR400. Nothing I could find related to my use case.
Unfortunately I'm 7-8 months out of warranty. Not sure it's worth spending a couple hundred $ for repairs when it works great under most conditions. I can just use one of my other X's for photographing Christmas I guess.
I was just curious if there might be a DIY solution for this.
Miguel-C
Im interested in a solution as well, i was looking to buy the XE3 but got cold feet due to reports of similar issues. Im sorry for your predicament, and i hope there is indeed a practical (and likely obvious) solution to the problem that we are missing.
Cordial Regards
Robmas4229
If I find a solution I will post it here. Unless you do a lot of indoor shooting with the camera pointed directly at LEDs you'll never notice it.
Robmas4229
Regarding the last sentence in my original post I meant to say XE3, not XT3.
skalsa1 Contributing Member • Posts: 655
 skalsa1's gear list:skalsa1's gear list
Canon EF 40mm f/2.8 STM
Robmas4229
skalsa1 wrote:
https://youtu.be/nSX4AKK_KgY
Thanks for the link. I already had my camera setup this way however.
Although unrelated, it doesn't seem wise to swap lenses with the power still on as he say he does in the video.
(unknown member) Contributing Member • Posts: 726
It is the nature of LED lights. They flicker at 60 or 50 hertz depending where you live. Older lights are more severe. Newer lights are better.
I have noticed this on all my digital cameras to some degree. I have shot theatrical performances in silent electronic shutter mode and had problems with those lights. One set had a large moon covered in LED rope lights and each frame only showed portions of it to be lit. Only way to have it fully lit was to shoot with shutter at 1/60 or lower which is not ideal.
Is there a way to change the LCD/EVF refresh rates?
Robmas4229
Thank you for replying.
This only happens with my XE3, not my X100v or XT2 with same settings.
I’m not aware of a way to change the refresh rate.
My XE-2 EVF did that almost all the time. Had no effect on the output though. I got used to it.
