looking to mark several open Safari windows by importance
andrzej bialuski Senior Member • Posts: 2,823
This is more of a general Mac question, but I am a photographer who needs a little bit of advice....
I have a tendency to constantly keep 5 or 6-7 Safari windows open on my Imac with 10 or more tabs in each one of them. Usually I try to group the tabs into separate windows by importance or subject like: fulfilling orders, research, personal crap and other more or less important subjects.
The problem I have is pretty obvious: I always have a hard time finding the windor that I am looking for, just because thy all look the same way.
Is there a way to somehow mark the top part of each window with a different color, which would be clerly visible on the screan?
Or perhaps to give each window a number or letter and with a click of a key have them all line up on the screen alphabetically or numerically?
Thanks in advance for your answers.
Andrzej
graybalanced Veteran Member • Posts: 6,887
Re: looking to mark several open Safari windows by importance
There are some features and also recent changes to Safari that should make this easier for you. If you are using the latest Safari:
If you right-click a tab, a menu pops up saying Arrange Tabs By: Title, or Website
If you have numerous tabs open and have no idea what is what, hold the mouse over a tab and a visual preview will pop up.
You can now "pin" tabs. If you drag a tab all the way to the left, it turns into a "pinned" tab (always present in a new browser window) using the website's favicon for easy visual reference. If you pin several websites, you end up with a row of icons that maintain their arrangement across windows and sessions.
If you open Safari Preferences and click on the Tabs panel, there is a preference "Use Command-1 through Command-9 to switch tabs." If that is switched on, then you can use those shortcuts to go straight to any of the first 9 tabs in the frontmost Safari window. If that is switched off, then Command-1 through Command-9 open the first 9 items on your Favorites Bar if you have set that up (View/Show-Hide Favorites Bar).
References:
https://support.apple.com/guide/safari/use-tabs-for-webpages-sfri11576/mac
https://support.apple.com/guide/safari/keyboard-and-other-shortcuts-cpsh003/mac
Martin.au
Martin.au Forum Pro • Posts: 14,121
Mission control perhaps? Perhaps combined with spaces.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
