Sony E-lenses on A7iii
Started 2 months ago | Questions
klondiker
klondiker Regular Member • Posts: 354
I'm thinking about changing my camera from A6300 to A7iii.  My line of lenses, all Sony, is as follows:
- E 50 1.8 OSS
- E 55-210 4.5 - 6.3 OSS
- E 10-18 4.0 OSS
- EPZ 18-105 4.0 G OSS
- FE 90 Macro G OSS
My question:  how these lenses will behave with new Sony A7iii?  Alternatively, perhaps I should try to sell them (except 90 macro) and purchase Tamron, or Sigma lenses of similar characteristics?  With new A7iii I will not need in lens stabilization after all.
Please advise and thank you.
gregn
 klondiker's gear list:klondiker's gear list
Canon PowerShot G7 X Sony a6300 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +3 more
Sony a6300
blue_skies
blue_skies Forum Pro • Posts: 12,013
Re: Sony E-lenses on A7iii
- E 50 1.8 OSS
- E 10-18 4.0 OSS
- FE 90 Macro G OSS
They will all work, but the APS-C crop is just a little over 10Mp. If that works for you (sufficient for Web, 4k monitors, letter paper prints), then you can use them.
Sony, Tamron and Sigma have a line of 'affordable' full-frame E-mount lenses that you could take a look at.
Also, you should search for specials, if you are not in a hurry. Some Black Friday/Cyber Monday discounts may still be applicable.
The IBIS in the camera works with the OSS in the lens.
Henry
Sony a6000 Sony a5100 Sony a7R II Sony DT 18-55mm F3.5-5.6 SAM Sony 75-300mm F4.5-5.6 +35 more
Aaron@Utah Senior Member • Posts: 1,629
- E 50 1.8 OSS
- E 10-18 4.0 OSS
- FE 90 Macro G OSS
depends what you will be replacing them with  you can still use the "E" lenses f you don't mind the 10mp in crop mode down  from 24mp in FF  you may be able to use the 50 and 55-210 without any vignetting in FF mode but forget about the 10-18 and 18-105  you will get all kinds of vignetting with those two   when used in FF mode
other than the 10-18mm you won't get much out of any of these lens on the used market. definitely not anywhere close to replacing them with their FF equivalent versions
I would probably keep the 6300 and 10-18 and 90mm and sell the rest to help pay for the a7III
Mac OS X: Because making UNIX user friendly was easier than fixing Windows.
 Aaron@Utah's gear list:Aaron@Utah's gear list
Sony RX100 IV Sony a6500 Sony a7 III Sony a6100 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +16 more
klondiker
OP klondiker Regular Member • Posts: 354
Thank you all for replies.  My decision is simple for now: stay where you are, that is with A6300.
gregn
Deniz Turkmen Junior Member • Posts: 43
I know you decided to stay with 6300 which is fine, but I was in a similar situation few months back. Luckily I did not own too many lenses, the only relevant crop lens I owned was 20mm f/2.8
Then I found this site that tested different crop lenses on an A7 body to show the effects. I decided I was OK with it since 20mm lens did not produce huge amount of vignette so I bit the bullet. You can check to see if they tested your lenses.
A7's can run in auto-crop mode where you won't see the vignette but I am manually cropping instead to save few more megapixels. Otherwise what's the point, better keep the old camera
I still bought a Tamron 28-200mm so I don't even use the 20mm anymore.
Shoot first, ask questions later.
 Deniz Turkmen's gear list:Deniz Turkmen's gear list
Sony Alpha NEX-6 Nikon D5500 Sony a7R II Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Sony 28mm F2.8 +3 more
klondiker
Deniz, thanks for the link.  With all that cropping I will be losing pixels and this is not what I want.  So, for the time being I'll stay with A6300 as sharpness is my main consideration for macro photography.
gregn
