How many megapixels are compressed xt2 raf files?
EOS GUY
EOS GUY Senior Member • Posts: 4,088
In faststone image viewer my xt2 lossless compressed files read only 2.46 MP.
But if I export them from c1 to cs6 they read in 'image size' as 4000 pixels by 6000 pixels which is 24mp.
Me not understand ;P
My Instagram - https://www.instagram.com/photonicstreetdreams/
The earth laughs in flowers.
-Ralph Waldo Emmerson
Before you say (or post in our context) = THINK.
Is what you're going to say - True. Helpful. Important (or Inspiring.) Necessary. Kind.
 EOS GUY's gear list:EOS GUY's gear list
Panasonic LX100 Canon EOS Rebel SL1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF-S 24mm F2.8 STM +6 more
boogisha
boogisha Senior Member • Posts: 2,153
Re: How many megapixels are X-T2 RAF files? 6000x4000, with embedded 1920x1280 preview JPEG
I guess what FastStone shows you when you open RAF file is its embedded JPEG preview instead, being on the smaller side (as reported, 1920x1280).
When you open RAW file in a RAW editor (as C1), you get to see actual RAW file being "developed" at its full resolution (6000x4000), and that is what you get to export, too.
p.s. Even (some?) RAW editors tend you show you JPEG preview image first, until RAW data is being processed in the background and ready for showing. Depending on how good editor is in replicating in-camera RAW to JPEG engine (but what your default editor settings are, too), you may see (much) more or less difference in what JPEG preview was showing and what actually processed RAW file shows once it appears.
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Canon EOS 5D Mark IV +12 more
Aoi Usagi Senior Member • Posts: 2,407
Re: How many megapixels are compressed xt2 raf files?
In Faststone, go into the setting menu.  In the "RAW" tab, change setting from "Embedded Preview Image (Fastest)" to "Actual Size (Slow)" and you will see the full raw file instead of the JPEG.
Formally Evogt500
 Aoi Usagi's gear list:Aoi Usagi's gear list
Fujifilm FinePix S200EXR Sony Alpha NEX-5N Fujifilm X-Pro1 Sony Alpha NEX-6 Canon EOS 70D +2 more
Greybeard2017
Greybeard2017 Senior Member • Posts: 1,684
Unfortunately Faststone doesn't convert lossless compressed Fujifilm files.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T3 Fujifilm X-T30 Fujifilm X-S10
EOS GUY
OP EOS GUY Senior Member • Posts: 4,088
Yourself and the above poster have provided me with the answer, thanks so much.
I also learned after some research that the lossless compressed really is lossless due to compression algorithms making the files smaller not loss of data.  I won't go into that as it is another topic but very happy to know all of this
