Wanting to view 80D images on PC in real time
Mascott Junior Member • Posts: 26
I am trying to view images on PC as I take them, because the LCD screen on my camera is much brighter and generally looks different to PC.
I have tried EOS Utility app, but it's temperamental and does little more than allow me to download images without removing the card.
Can anyone recommend a simple method to view images as they're being taken? One that allows for zooming to check focus? Thanks
Canon EOS 80D
Boomanbb
Boomanbb Veteran Member • Posts: 3,002
Re: Wanting to view 80D images on PC in real time
You want a wired solution, WIFI options are not real time. I have tried tethering with Lightroom but it can get flaky sometimes. The best option would be if you had an iPad. Cascable has wired tethering and it works very well. You can zoom in to check focus, control camera functions, import raw files and lots of other stuff.
If that doesn't work for you, consider an HDMI capture dongle or card.
Ben Boozer
Disagree without being disagreeable
 Boomanbb's gear list:Boomanbb's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EOS M3 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm f/2.8L USM +12 more
Ray UK Contributing Member • Posts: 797
EOS utilty will do this perfectly if you connect the camera to the PC with a USB cable, it gives you access to all camera controls and allows real time monitoring, forget the wi-fi connection it won't help you at all.
S Castle
S Castle Senior Member • Posts: 1,104
I have a 70D, and if the 80D and 90D WiFi is the same then yes, it is essentially crippled, probably because the processor in the camera is just not up to it. Using the USB cable is not terrifically fast but it's bearable.
I have experimented with using the EOS Utility, Lr, and Capture 1 for this. Of these, C1 worked the best and Lr the worst (but that was with 5.7.1 - maybe it's better now). The EOS Utility is, um, OK. I shoot raw, so the xfer is slow anyway.
If only the 90D had been made to use USB3. But no...
Shane
OP Mascott Junior Member • Posts: 26
Thanks for all the comments and suggestions. Is it possible to connect using HDMI cable?
Boomanbb
Yes, with the proper cable you can go direct and in real time to an hdmi monitor. I did that in my studio with a 50 inch display.
Ben Boozer
Thanks, I have a HDMI cable, but am having no luck connecting it to the PC
Boomanbb
Ok, let’s get this straight. You can only connect that hdmi cable to either a hdmi monitor or a hdmi capture card or dongle. You cannot connect it to a pc.
Ben Boozer
John Sheehy Forum Pro • Posts: 24,184
Well, the 7D2 has a USB3 port, but does less than 10MB/s delivering images to the computer, tethered, so just having USB3 alone isn't enough, if the rest of the chain is not up to it.
EJ Fudd
EJ Fudd Senior Member • Posts: 1,738
once the image is taken it no longer real time..its the past (nt)
"The fact is that relatively few photographers ever master their medium. Instead they allow the medium to master them and go on an endless squirrel cage chase from new lens to new paper to new developer to new gadget, never staying with one piece of equipment long enough to learn its full capacities, becoming lost in a maze of technical information that is of little or no use since they don't know what to do with it."
A Great Quote by Edward Weston...
 EJ Fudd's gear list:EJ Fudd's gear list
Canon EOS 5D Mark IV Canon EOS 90D Canon EF 400mm f/5.6L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L IS USM +17 more
