Shoulder bag recommendation for 2 x bodies and 2 x lenses (attached)
Started 4 months ago | Questions
davidevans1 Senior Member • Posts: 1,832
I asked this question on the accessories forum initially, but think I will have a better chance of a knowledgeable reply here.
Any recommendations please for a shoulder bag that will fit 2 x Sony A7 series bodies each with a lens similar size to the Sony 24-70 f/2.8 GM lens attached? Both cameras also with tripod L brackets fitted.
Must be with the lenses attached and ideally with the lens hoods attached also, but I'm fine if these are fitted reversed on the lenses.
That’s it, doesn’t have to carry much else except a few small accessories.
Finally I’m in the UK so ideally a bag that’s available here.
Thanks in advance for any help.
David
Sony a7
mujana Veteran Member • Posts: 7,366
Re: Shoulder bag recommendation for 2 x bodies and 2 x lenses (attached)
As I just said in the accessories forum:
I love my Billingham shoulder bag. You might take a look at their collection. And...British.
 mujana's gear list:mujana's gear list
Sigma DP3 Merrill Sony a7R IV Zeiss Batis 85mm F1.8 Sony FE 16-35mm F2.8 +6 more
OP davidevans1 Senior Member • Posts: 1,832
Mujana, thank you and a Billingham bag would definitely be an option. Do you have two camera bodies and lenses and carry with two lenses attached, or is it a general suggestion for the Billingham range? Does anyone know if the Hadley Pro would fit 2 x bodies with 24-70 F/2.8 lens size fitted?
David
noggin2k1
noggin2k1 Senior Member • Posts: 2,741
I use the Peak Design Everyday Sling 6L - that gets me either;
  • 1 body w/fast prime attached + 24-70/2.8
  • 2x 24-70/2.8 sized lenses + flash
I'd have thought their 10L version would be a great fit for what you're after. Lots of really nice features to the bag, and really well made - definitely recommended my end.
 noggin2k1's gear list:noggin2k1's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 35mm F1.4L II USM Canon RF 50mm F1.2L USM Canon RF 15-35mm F2.8L IS USM +3 more
Mike Evangelist
Mike Evangelist Contributing Member • Posts: 601
davidevans1 wrote:
...a shoulder bag that will fit 2 x Sony A7 series bodies each with a lens similar size to the Sony 24-70 f/2.8 GM lens attached? Both cameras also with tripod L brackets fitted.
I use a Peak Design 10L Sling for that setup (2 bodies, 12-24 GM & 12-24 Sigma). Works very well.
 Mike Evangelist's gear list:Mike Evangelist's gear list
Sony a7R IV Zeiss Batis 135mm F2.8 Sony FE 200-600 F5.6-6.3 Samyang AF 18mm F2.8 FE Sigma 24-70 F2.8 DG DN +1 more
Thank you that's great.
David
Hi Mike (and Noggin2k1) thank you and especially for the photographs. I'm being a bit stupid as I have the 10k Peak Design bag and use it with one body and lens attached lying horizontal lengthways and one lens vertical. I'd assumed I wouldn't fit two bodies and lenses attached, but obviously got that wrong! I have a second body on order so that should save shelling out for another bag.
Mike - that's the Mark 1 10l bag isn't it? It looks like the one I have which is also a Mark 1 version.
incidentally I also requested the free Peak Design Sling Strap Lock Kit (SSL-KIT-1) to stop the shoulder strap accidentally undoing.
David
Mike Evangelist
Yes, it's a Mark 1, which I prefer in the 10L size. (I also have a 6L Mark II).
I haven't had much trouble with it slipping, but I should probably get those anyway, just in case.
Hello David. First of all it’s a recommendation for Billingham bags in general. Sturdy / very good protection and comfortable. I do not own the same equipment as you want to put in a shoulder bag. In my equipment list you can see my photo gear. Everything fits nicely in my Billingham. If you buy one, I definitely also recommend the shoulder pad from Billingham.
