100-400 S lens with TC 1.4 or 2.0 working on Z6?
z2122
z2122 Senior Member • Posts: 1,395
In the Canon RF forum people are discussing the use of the Canon 100-500 with TCs on the R5 and it seems to work quite good.
I have a z6 and when the 100-400 S lens will be released I would get one with a T,"c ( most probably the 1.4). Looking at the size of the lens compared to other lenses on the roadmap, most probably the 100-400 will be f5.6 or f6.3 on the long end . Mostly I will use that combo for not movin subjects or big animals .
What is your opinion? Will such a f5.6/f6.3 lens work acceptable on a Z6 with a TC or is there a big difference in AF capabilities between Z6 and R5? ( or Z6 II)
catch the light - explore emotions
 z2122's gear list:z2122's gear list
Nikon Z6 Nikon AF-S Nikkor 70-200mm F4G ED VR Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 14-30mm F4 +9 more
Canon EOS R5 Nikon Z6 Nikon Z6 II
PLShutterbug Contributing Member • Posts: 813
Re: 100-400 S lens with TC 1.4 or 2.0 working on Z6?
5
I have the 200-500/5.6 Nikkor and use it with the TC14-III with my Z7. I’m sure the Z 100-400 and 1.4 will be fine.
 PLShutterbug's gear list:PLShutterbug's gear list
Sony RX10 IV Nikon D7100 Nikon Z7 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +4 more
Ernie Misner
Ernie Misner Veteran Member • Posts: 7,210
TC's are designed for telephoto lenses such as primes and high quality zooms.  So far the TC's work fantastic with the 70-200 S and hopefully with the upcoming 100-400 as well.  Focusing speed could be slightly slower at the f6.3 end.
Ernie Misner
http://www.flickr.com/photos/erniemisner/
The first digital image was made in the late '60's for NASA, as a way to record images of Mars. Each "square" was represented by three numbers, corresponding to the red, green, and blue hue on a scale of 0 to 255. This eliminated the need to ship film back to Earth.
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon Z 24-70mm F4 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED +6 more
msu79gt82 Senior Member • Posts: 1,296
I am definitely interested in the 100-400 S, especially if it's a 5.6 on the long end. Its silhouette is more in line with the size of a lens I'd want; the 200-600 appears to be too large for my liking.  I reserve the right the change my mind post release.
Hence, I could be interested in the Z TC 2.0x so hopefully it'll work just fine. At the moment I have very little interest in the Z TC-1.4x, I'll just use the Z50.
 msu79gt82's gear list:msu79gt82's gear list
Nikon Z6 Nikon Z50 Nikkor AF-S 300mm f/4E PF ED VR Nikon AP-F 70-300mm F4.5-5.6E Nikon Z 24-70mm F4 +6 more
Digital Shutterbug Veteran Member • Posts: 5,190
Obviously, this is a thread with not much more than speculation since Nikon is holding facts tightly. Given that, I can't imagine the 100-400 S model lens being anything slower than f/5.6 on the long end. I reach that conclusion based on the F mount 200-500mm being f/5.6 from end to end. Like PLShutterbug, I use that lens, along with the TC 1.4, for completely satisfactory results on my Z7.
My only complaint about the 200-500 is the size and weight, especially coupled with the FTZ on the Z7. It's hand-holdable in good light for short durations. I'm hoping the Z lens 100-400 will be smaller and lighter. With current lenses being so good, I think the 100-400 will be on the same plane. After all, it is an S Line lens. That would make me inclined to replace my 200-500 with the 100-400.
I don't want to sacrifice the extra 100mm on the long end, but the Z model teleconverters are proving to be exceptional. Assuming the 100-400, combined with the 2X tele, gives the image quality I think it might, I'll be all in. Nikon, please don't spoil that with a price tag longer than the lens.
Steve
1llusive
1llusive Veteran Member • Posts: 3,304
Problem with asking for smaller and lighter is smaller apertures. But if I had to guess...
100-400 4.5-5.6
x1.4 = 140-560 6.3-7.8 (might officially be f/8)
vs
200-600 4.5-6.3
The 200-600 will certainly offer a larger aperture if you're willing to lug the beast around. Tripod recommended for that one.
 1llusive's gear list:1llusive's gear list
Nikon Z6 II Sigma 100-400mm F5-6.3 Nikon Z 24-70mm F4 Nikon Z 85mm F1.8 +1 more
100-400 4.5-5.6
vs
200-600 4.5-6.3
But the Z lens is only a 100-400mm, in place of a 200-500mm. I'm thinking it will be the same f/5.6, giving it a chance of being somewhat smaller and lighter. My fingers are crossed, anyway.
Now, the 200-600, that's another beast altogether. Being an S line lens, I figure it will be superior in many ways. Superior is another word for big, heavy and costly. Probably beyond my needs or financial capability. We'll see.....
Steve
William Belvin Contributing Member • Posts: 570
I thought the 200-600 is not s-line
For info about Coyote Buttes or 'The Wave' try my site:
https://www.thewave.info
 William Belvin's gear list:William Belvin's gear list
Nikon D810 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR
You're absolutely right. I've got the two reversed. Thanks.
Steve
Re: 100-400 S size ??
100-400 4.5-5.6
vs
200-600 4.5-6.3
According to the published photo of the Z roadmap, the 100-400 S silhouette appears to be about the same size as the Z 70-200f/2.8 S.  So it will be considerably smaller and lighter than the 200-600 whose silhouette appears to be in ballpark of the 400 and 600 S primes.
Straz Regular Member • Posts: 251
For what it's worth, the 70-200mm F2.8 already works quite well with the TC 2.0 for an effective 140-400mm F5.6.
Since I already own that combo, I don't expect to be interested in another longer zoom.
One thing I did learn yesterday is that the 24-200mm F4-6.3 travel zoom, when used at 200mm to take golden hour photos of birds has trouble with fast-movers at ASA 64 on my Z7, so I would expect the same to be true of any other combination of long focal length and dim F-stop.
 Straz's gear list:Straz's gear list
Nikon Z7 Nikon Z 24-70mm F4 Nikon Z 50mm F1.8 Nikon Z 14-30mm F4 Nikon Z 70-200 F2.8 VR +4 more
100-400 4.5-5.6
vs
200-600 4.5-6.3
If I've seen that photo, I don't remember it. Do you think the 100-400 might be an f/4? That would be very nice. I'm thankful to have a 200-500 that performs as well as it does. It's probably what I will have for some time to come. I dream a lot more than buy.
Steve
The diameter of the 100-400 appears to be a bit less than the 70-200 2.8 so who knows?
Thank you. I do think I remember seeing that. The 100-400 does bear a striking resemblance to the 70-200 f/2.8 in size. How nice would that be compared to the big honkin' 200-500? Oh, to be rich and have a 100-400, paired the new 600 and TC's.
Steve
Back in the day, a 2.0 TC was simply a poor man's way of getting extra focal length. I was never impressed with anything beyond 1.4 X. The new Z lens and 2 X combo has changed my mind on that. I've been impressed with images I've seen.
I barely had time to use my 24-200 before shipping my Z7 to Nikon. I'm not surprised that it might be sluggish at lower light levels. I hope the Z7 II might be helpful under similar conditions, but that remains to be seen. You're showing your age when you speak of ASA.
Steve
z2122
OP z2122 Senior Member • Posts: 1,395
100-400 4.5-5.6
vs
200-600 4.5-6.3
When I compare the size if the 100-400 S lens with the much bigger 180-400 f4 it is very unlikely that the S lens will have f4 on the long end.
Most probably it will be a f4.5-f5.6 as the existing 80-400 F mount lens.
1llusive
100-400 4.5-5.6
vs
200-600 4.5-6.3
Yup, zero chance. f/4 would be a 100mm aperture. It will likely have in the ballpark of a 70-75mm aperture. I think it will be a very versatile lens with a 1.4 TC.
Your welcome.  Oh, to be rich ...
... I do suspect that they won’t be cheap, but hopefully the 100-400 won’t be unreasonable.
100-400 4.5-5.6
vs
200-600 4.5-6.3
You’re probably right; I was wishing that with an opening size equivalent to the 70-200f/2.8 along with the Z-Mount diameter perhaps f/4 was possible.  I guess it’s a win-win because I’d love to have an f/4 that size but I want the price of an f/5.6.
I suspect you're right. What made me think it might be an f/4 is the current history of S-line lenses. Correct me if I'm wrong, but I think all S zoom lenses have been constant aperture, and none slower than f/4. That doesn't mean Nikon will adhere to that scheme.
Steve
