Problem with internal charging (NX500)
Started Dec 2, 2020 | Discussions
thatfour Junior Member • Posts: 38
while charging i notice the charging led turn red & green continuously, it seems still no power to turn on after overnight charging. is my battery dead? any idea where to get the batteries from this already camera system?
thx
markyboy81 Veteran Member • Posts: 4,778
Re: Problem with internal charging (NX500)
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
OP thatfour Junior Member • Posts: 38
have to be sure the problem is with the batt or the camera
Good point, but at least if the issue is with the camera not charging the battery you could use an external battery charger.
link gaetz Forum Member • Posts: 98
I've had problems with the USB on my NX500, both with file transfers and charging. I dug out an old phone charger with a fixed cable and that seems to work consistently, compared to some chargers with removable cables that are flakier.
