External hdmi video recorder-monitor for Nikon d750
George Worst New Member • Posts: 15
Hello everyone.
Can anyone suggest me an external hdmi recorder-monitor at least 5” big and supporting 1080p 60fps? I was thinking about Atomos ninja 2 but it seems it doesn’t support 60fps. I was also thinking about Atomos ninja V but since my camera (Nikon d750) doesn’t record 4K and therefore I don’t need 4K and my budget is limited I would like a cheaper alternative because I could spend the extra money in other equipment like a gimbal or such.
Thank you in advance,
George
Nikon D750
I am Bowie Forum Member • Posts: 71
Re: External hdmi video recorder-monitor for Nikon d750
George Worst wrote:
Hello everyone.
George
If a new Ninja V is not a choice and price is an issue - and 1080p support is required, then the choices are limited really to a used/refurbished Ninja V or a new/used/refurbished BlackMagic Video Assist 3G-SDI/HDMI 5.
Theres not much else available in the sub-$500US range in on-camera monitor/recorders that support 1080p/60.
The BlackMagic model is less expensive than the Ninja V by enough that allows money fir accessories.
 I am Bowie's gear list:I am Bowie's gear list
Nikon D3S Nikon D750 Nikon D7500 Nikon AF Nikkor 14mm f/2.8D ED Nikon AF Micro-Nikkor 60mm f/2.8D +8 more
George Worst wrote:
Hello everyone.
George
George,
Just wondering, I have a D750 also —- are your videos mainly to be viewed on mobile (ie like YouTube) or a monitor/projection screen?
If your viewers are just mobile and there’s not a lot of fast movement (ie sports), then 720p/60 is more than sufficient for vlogging and you can save even more money by just getting a used Ninja 2 with all the $$$ accessories on eBay (from someone that is moving to 1080p/HD/4K/etc).
YouTube downgraded 720 to SD this year (it was HD), so you can probably scoop up an older on-camera vlogging outfit on the cheap.  Most vids are defaulted to 720 in YouTube anyway or users select 720 or below (cause you can’t tell the difference between 720 and +1080 on a phone screen and no one likes video freeze).
