Compact wide angle lens?
Scriv
Scriv Contributing Member • Posts: 899
I'm looking to build a small travel kit based on an XT30. I've already settled on the Fuji 23/f2, 35/f2, and 50/f2 lenses but I want a compact wide angle lens for landscapes. Something in the 15-20mm equivalent. I'm open to Fuji or third party brands, a prime is preferred but I'd consider a compact zoom. Any recommendations?
 Scriv's gear list:Scriv's gear list
Sony RX100 V Fujifilm X100V Canon EOS 7D Mark II Canon EOS 5D Mark IV Fujifilm X-T30 +12 more
dc_tonk Regular Member • Posts: 430
Re: Compact wide angle lens?
The 16/2.8 is smaller than its f/1.4 sister.
10-24 is the native zoom option.
Rokinon 12 is highly regarded as well.
Compactness may vary depending on perspective.
 dc_tonk's gear list:dc_tonk's gear list
Fujifilm XF 35mm F1.4 R Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm Fujifilm X-T3 +14 more
maxxxx Contributing Member • Posts: 931
Both Rokinon 8 and 12 are pretty small.
 maxxxx's gear list:maxxxx's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 10-24mm F4 R OIS Samyang 12mm F2.0 NCS CS +4 more
7rvar Regular Member • Posts: 214
16mm f2.8 seems like the obvious answer.
14/27/60 or 14/18-55/60 are also nice for travel. It really depends on your style,
I like 23 f1.4, 56 f1.2 and Samyang 12 with my X-T20 because I often take pictures in low light.
How about Zeiss 12mm with Viltrox 23 and 56.
Too many possibilities but still 16mm f2.8 seems like the obvious answer.
If I didn't have 3 cameras how would I take pictures of my 2 cameras?
 7rvar's gear list:7rvar's gear list
Fujifilm X-E2 Fujifilm X-H1 Fujifilm X-A7 Fujifilm XF 18mm F2 R Fujifilm XF 14mm F2.8 R +4 more
sluggy_warrior Senior Member • Posts: 2,598
panorama?
Just thinking outside the box/lens a bit: it doesn't cost much to practice taking panorama. I travel with just the 18-55 or 18-135 and can still take really wide angle shots (wide angle lens is not wide enough for me)
It's relatively easy: lock exposure, put my left thumb under nodal point of the lens, snap, rotate, snap, ... There're many stitching softwares that automate most of the works, I use the free/open-source Hugin, it's very straightforward.
I'm very lazy, I don't spend more than 10 minutes on a pano. You can see the misalignment of the tree near top-right corner, easy to fix with a mask in Hugin, but I'm too lazy
9 vertical shots, RAF processed in darktable, exported to TIFF, stitched with Hugin.
McWoodley
McWoodley Regular Member • Posts: 345
Compact?  While I don’t own it the 16 2.8 smallest WA with the 15-45 about the same
How wide, how fast and what do try plan to use it for?
The Rok 12 isn’t what I would call compact but it’s not huge.  Great for Astroscapes and some landscapes.  Obviously no AF but not a huge deal with such a wide  lens.
The 10-24 is far from compact and isn’t fast but is a great and flexible lens that can cover all kinds of situations other than residing in a pocket. I have the Mieke hand grip on my xt30 and no issues handling larger lenses
It really just depends on what FL you are waning.  The 16 2.8 seem like the obvious fit to your kit especially given your choice of primes, unless you are wanting wider or to do nightscapes.  Then the Rok 12
the 15-45 has it flaws but it’s inexpensive and works well wide open.
Outlier is the 18 1.4 coming out or even the current version if you really want compact it is practically a pancake.  Pixel peepers dis it but from most photos I have seen it had a lot of character.  Maybe a bit close to your 23 though and not really filling that WA area.
 McWoodley's gear list:McWoodley's gear list
Fujifilm X-E1 Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +7 more
superpig000 Regular Member • Posts: 127
As above, the Samyang/Rokinon 2/12 is highly regarded. Roy Cruz is one of my favourite photographers (and Fujifilm user) and he has some really good things to say about the lens... and the pictures really talk for themselves.
https://blog.roycruz.com/a-tribute-to-a-great-lens-the-samyang-12mm-f2-0-ncs-cs-long-term-review-2017/
 superpig000's gear list:superpig000's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +1 more
Gaber
Gaber Veteran Member • Posts: 6,224
The XC15-45 lens is small, compact, light as a feather and reasonably priced. Ideal for a travel kit. I have both the XF10-24 and the  XC15-45 and I wouldn't hesitate to bring the XC lens on vacation. The IQ , while not in the league with the XF, is a very sharp lens.
 Gaber's gear list:Gaber's gear list
Nikon Coolpix 4500 Olympus Tough TG-2 Nikon 1 J5 Fujifilm X-E3 Nikon AF Nikkor 50mm f/1.4D +13 more
ninjagowoo
ninjagowoo Regular Member • Posts: 159
Surprised no one has mentioned the 18mm f2 yet. (or maybe I just missed it)
 ninjagowoo's gear list:ninjagowoo's gear list
Fujifilm X-T2 Fujifilm X-H1
jjz2 Senior Member • Posts: 2,748
obvious choice seems to just complete the "cron" set and get the 16 2.8.
 jjz2's gear list:jjz2's gear list
Fujifilm X-T20 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +2 more
Street_Photography
Street_Photography Senior Member • Posts: 1,702
Scriv wrote:
...15-20mm equivalent. I'm open to Fuji or third party brands, a prime is preferred.... Any recommendations?
New rockstar 10mm f8 fisheye $67 (15mm equivalent)
Of course the Samyang 12 or Zeiss 12 would be better, but also cost far more and weigh more.
IQ is a mixed bag in the first look images, some softness at sides in some images has taken my finger off the ordering trigger until reviews come out.
To be honest, I wouldn't use the above for landscapes, I may just use for casual street. For landscapes the 15mm f3.5 stabilized $100 Fujifilm lens is superb (if you are on a budget) and it is as wide as the 14mm, making it almost fit your 15-20mm equivalent range at 21mm. It is the 15-45mm kit zoom and there are comparison posts on this forum that show it is just as sharp and wide as the 14mm prime, except for slightly weaker corners. It is definitely sharp enough for landscape photography.
 Street_Photography's gear list:Street_Photography's gear list
Fujifilm X-E2 Fujifilm XF 27mm F2.8 Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50mm F2 R WR 7artisans 7.5mm F2.8 Fisheye +1 more
Artur Darulewski Regular Member • Posts: 263
Laowa 9mm/2.8
I think you may consider Laowa 9mm f/2.8 Zero-D as well - small and highly regarded lens.
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +8 more
jhorse Veteran Member • Posts: 4,505
Hi, of course the two questions are how wide and what budget?
I have the 23/f2 and 50/f2 and the 16/f2.8 is a great wide angle addition. I used to have the 14/f2.8, which delivered excellent IQ (if one is wedded to nothing wider than 15mm, one can crop), but I traded it for a 10-24 as I wanted more versatility on occasions.
As a small, discreet generalist kit the 16/23/50 on a XE3 (or XT30) is my favourite option.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +6 more
Eduard
Eduard Contributing Member • Posts: 571
Re: Laowa 9mm/2.8
Artur
Totally agree with the Laowa 9mm recommendation. For size comparison, L-R: Laowa 9mm, Fuji 16mm/2.8, 23mm/2.0, 35mm/2.0 and 50mm/2.0.
 Eduard's gear list:Eduard's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +5 more
