What lens?
Started 4 months ago | Questions
TomWret
TomWret Veteran Member • Posts: 3,938
What lens?
What do you believe is the sharpest "prime" between 28mm and 100mm? That fits the K series without an adapter?
Thanks, Tom W
...a bad picture is like a missed putt, it's never your fault: My new site https://fineartamerica.com/profiles/3-thomas-whitehurst
 TomWret's gear list:TomWret's gear list
Pentax K-1 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited Pentax smc D-FA 100mm F2.8 Macro WR +9 more
flektogon
flektogon Veteran Member • Posts: 4,737
Re: What lens?
Thanks, Tom W
I believe that two of them (31mm, 100mm) you already have .
Peter
Massao Senior Member • Posts: 2,580
Re: What lens?
Thanks, Tom W
Sigma 35mm f/1.4 DG HSM Art and DA 35mm Macro f/2.8 Limited
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +41 more
Alex Sarbu Forum Pro • Posts: 11,984
Re: What lens?
5
Thanks, Tom W
I would look at the D FA* 50mm f/1.4 and the D FA* 85mm f/1.4.
Alex
"When you tear out a man's tongue, you are not proving him a liar, you're only telling the world that you fear what he might say." - George R.R. Martin, A Clash of Kings
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +8 more
zakaria
zakaria Veteran Member • Posts: 5,478
Re: What lens?
Alex Sarbu wrote:
Thanks, Tom W
And dfa 50mm macro.
Alex
pentaxian .
 zakaria's gear list:zakaria's gear list
Nikon D750 Fujifilm X-H1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited HD Pentax DA 21mm F3.2 AL Limited +7 more
Holger Bargen Veteran Member • Posts: 4,388
Re: What lens?
Thanks, Tom W
I would guess D FA* 85 mm f 1.4.
It's a portrait lens - however it gives enormous resolution. Sharpness comes from processing ...
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
PeterPentax
PeterPentax Contributing Member • Posts: 907
Re: What lens?
Alex Sarbu wrote:
Thanks, Tom W
Alex
I have both and agree.
TomWret
OP TomWret Veteran Member • Posts: 3,938
Re: What lens?
Thanks to all, it looks like it is going to favor the 50mm and 85mm lens'. Maybe I'll live long enough to pick one up on ebay.😁
Tom W
DougOB
DougOB Senior Member • Posts: 1,964
Re: What lens?
zakaria wrote:
Alex Sarbu wrote:
Thanks, Tom W
And dfa 50mm macro.
I have heard the DFA 50/f2.8 Macro is very sharp, even more than the DFA 100/f2.8 Macro which I have and find quite sharp.  I do not have the 50 since I have already many lenses covering this range and also macro.
It is / would be more affordable than the DFA* options.  Smaller and lighter too if that is a factor.
Doug
Alex
 DougOB's gear list:DougOB's gear list
Pentax K-01 Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +32 more
TomWret
Re: What lens?
Thanks Doug. I'll check that out.
Tom W
bkpix
bkpix Contributing Member • Posts: 951
Re: What lens?
The 70 2.4 Limited is small and sharp can can be used on full frame as well as crop.
 bkpix's gear list:bkpix's gear list
Pentax K-5 Pentax K-5 IIs Canon EOS 6D Canon EOS 7D Mark II Pentax KP +13 more
xmeda
xmeda Senior Member • Posts: 1,500
Re: What lens?
Sigma 35/1.4 Art
Most resolving K mount AF lens so far with minimum CA (has less CA than DFA* 50/85).
Then both DFA*50 + DFA*85 and then FA31/1.8 followed by FA77/1.8
And also DFA50/2.8 Macro can resolve huge amount of detail if you need something rather affordable and your working aperture is between F4-F11. Similar thing is Sigma 70/2.8 Macro.
DFA100/2.8 WR Macro follows, but has more CA and needs some more aperture to shine.
DA35/2.8 Macro can deliver nice results too, with F5.6+.
If zoom, then Sig 18-35/1.8, Sig17-50/2.8.
So it depends on budget, optimal focal length for the application and desired AF performance too. There are things like Zeiss ZK 35/2 manual focus only, which can render stunning details, but is hard to find and is manual focus only.
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Nikon Coolpix P7800 Olympus Stylus 1s +33 more
TomWret
Re: What lens?
Thanks xmedia, I have the DFA 50mm 2.8 macro and I'm going to try it out tomorrow.
Tom W
zakaria
Re: What lens?
DougOB wrote:
zakaria wrote:
Alex Sarbu wrote:
Thanks, Tom W
And dfa 50mm macro.
I have it .it's maybe the sharpest Pentax lens .
Doug
Alex
pentaxian .
Re: What lens?
xmeda wrote:
Sigma 35/1.4 Art
I consider CA alway as a minor problem. It can be removed in post-processing the easy way - and how much CA is left if you shoot with in-camera correction set ON?
And resolution as well as CA is just one side of the coin. The overall rendering is influenced by a lot of other factors like colour rendering, 3D pop (maybe caused by a well balanced microcontrast), performance against the light.
I prefer Pentax always because its coating does well in situations where you shoot against the light (and I do it very often). Some lenses end up with a strange soup of reflections, ghosting or strange colours.
I have this 70 mm Sigma lens. Regarding AF it is a snail. However, if it comes to sharpness and also overall performance, this lens shines. I was even thinking twice before buying D FA 85 if this old Sigma lens is not all I need. I did also nice portraits with it. I think it is only availabe as used - and you may get it for little money.
I think the 100 mm Pentax macro is based on the old Tokina lens design. I have a couple of macro lenses of this class - but this one is still missing. When I informed myself about these lenses I found that the Tokina lens has not best resolution but best rendering in terms of a harmonic look of the photos. If you don't do pixel peeping you may prefer this lens over the others due to its great rendering.
Re: What lens?
Tom W
That's a nice lens. I have FA 50 mm macro and it is one of the sharpest lenses in my bag. However, if you go for insects, distance between lens and subject may be a little small. But for everything else - a nice lens which can produce photos that shine.
KL Matt Veteran Member • Posts: 5,961
FA 43 Limited
n/t
... interested in .... photographs? Heh? Know what a mean? Photographs? (He asked him knowingly). Nudge nudge, snap snap, grin grin, wink wink, say no more, say no more, know what a' mean? Know what a' mean?
http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=183820&subSubSection=0&language=EN
