a7r2 flash sync max 1/125sec
Donald B
Donald B Forum Pro • Posts: 18,011
any idea why i cant  fire my studio strobes faster than 1/125sec ? my em12 is as high as 1/320sec using catus v5 radio triggers.
Don
Olympus EM1mk2, Sony A7r2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1 em5mk2
Magnar W
Magnar W Veteran Member • Posts: 5,463
Re: a7r2 flash sync max 1/125sec
Depends on the camera shutter and tupe of flashes.
With studio flashes you might not reach the limit for sync speed for speedlites. This is true for Sony cameras when using Elinchrom or Bowens flashes.
 Magnar W's gear list:Magnar W's gear list
Sony a7 Sony a7R III Sony FE 90mm F2.8 macro Zeiss Loxia 21mm F2.8 Zeiss Loxia 35 +2 more
cyberpi1 Regular Member • Posts: 466
Don
A7R II has a flash sync speed of 1/250 s. Everything below is caused by the trigger.
 cyberpi1's gear list:cyberpi1's gear list
NEX-5T Pentax 645Z Sony a7R IV Sony E 16mm F2.8 Pancake Pentax smc D FA 645 55mm F2.8 AL (IF) SDM AW +4 more
A-Marc
A-Marc Contributing Member • Posts: 720
Don
mine syncs with 1/250 Godox trigger.
 A-Marc's gear list:A-Marc's gear list
Sony a7R II Sony a7R IV Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 55mm F1.8 Zeiss Batis 25mm F2 +3 more
Jeff2013
Jeff2013 Veteran Member • Posts: 3,028
When I shot A7RII's, all my Sony speed-lights, Paul Buff studio strobes and Godox studio strobes synch'd at 1/250 just fine.
I had shot at several studios (using their strobes) that had old or off-brand strobes that would not synch over 1/125. I'm not sure if it was related to their triggers or their strobe units. I never had problems with Elinchrom strobes/triggers.
 Jeff2013's gear list:Jeff2013's gear list
Sony a9 Sony a7R IV Sony FE 90mm F2.8 macro Sony FE 70-200mm F2.8 GM OSS Sony 1.4x Teleconverter (2016) +11 more
Donald B
OP Donald B Forum Pro • Posts: 18,011
the problem is they can fire at 1/250 sec just that theres a shadow down 1 side yet with the same lighting eqip my em12 is fine even at 1/320 sec
don
Jeff2013
don
That is the same problem I had with the old strobes.  You might play with the stop down settings.  Does the effect stay the same at f2.8 and f8?
Donald B
don
same at f8 and 2.8 the godox strobes a fairly new. Doesnt really matter i can live with it will just freeze action by lowering the strobe power.
Don
