R5: eye AF box and what's displayed in DPP (4.13.x)
pawn Senior Member • Posts: 2,880
Hi
I just received my R5 a few days and am learning its AF's capabilities. Below is an unprocessed picture that I took with eye AF engaged. Note that the red box displayed in DPP is off the eye.
Is the focus a little off? Or is there a bug in DPP when displaying the red box? BTW, I normally stop down (f/6.x or even f/8) so minor issues like this does not matter to me.  I am just curious.
Duy
Canon EOS R5
PMUK
PMUK Senior Member • Posts: 1,306
Re: R5: eye AF box and what's displayed in DPP (4.13.x)
pawn wrote:
Hi
Duy
Hi Duy,
Not sure what's wrong with the upload, but no image is being shown.
I don't use DPP much, but you can set your R5 to show you the focus point(s) used during playback which may either help in the first instance, or to check against DPP.  (See below).
Phil
 PMUK's gear list:PMUK's gear list
Sony RX10 IV Sony RX100 VI Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS R5 +9 more
OP pawn Senior Member • Posts: 2,880
PMUK wrote:
pawn wrote:
Hi
Duy
Hi Duy,
Phil
Thanks Phil
Not sure what happened.  Let's try again:
RDM5546
RDM5546 Senior Member • Posts: 2,183
pawn wrote:
PMUK wrote:
pawn wrote:
Hi
Duy
Hi Duy,
Phil
Thanks Phil
DId not show again.  Is that a JPG or  a RAW file?
 RDM5546's gear list:RDM5546's gear list
Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS R +38 more
RDM5546 wrote:
pawn wrote:
PMUK wrote:
pawn wrote:
Hi
Duy
Hi Duy,
Phil
Thanks Phil
I copy a portion of the DPP's screen and then pasted it in.  It showed for me.
PMUK
pawn wrote:
RDM5546 wrote:
pawn wrote:
PMUK wrote:
pawn wrote:
Hi
Duy
Hi Duy,
Phil
Thanks Phil
Hi Duy,
What I do is - capture a screen shot (on my iMac it gets saved to a *.png file), then use the [Insert image] tool from the forum's [post toolbar] to select/ upload the file into your post.
That should work.
Phil
Steve Balcombe Forum Pro • Posts: 14,248
Yep, as it happens I've used that technique in Facebook Messenger just this morning. However I don't think Dpreview supports it, you have to use the "Insert image" button.
