A200 Battery Trouble
Started Nov 28, 2020 | Discussions
Hike Pics
Hike Pics Senior Member • Posts: 2,917
I just charged one of the batteries for my A200 up to full. I checked the voltage and it's at 7.91 volts. When I power the camera up it shows an almost depleted battery icon. I get maybe 15 to 30 seconds and then it shows "Battery Exhausted" and shuts down. I have never had this issue before. I have another battery that is currently at 6.63 volts and, as you could figure, the camera won't even power on.
I have no idea what's going on. There's nothing odd in the battery compartment. I don't have a DC power supply to test that. I really don't want this to be my 2nd DiMAGE I've had to throw away this year!
...Wes...
Konica Minolta DiMAGE A200
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: A200 Battery Trouble
When I get chance over the next few days I'll take a few readings off my batteries , both as they are when they've been sat for a while and what they are fully recharged .
They might not hold as much charge as what they used too , but it might give a clue as to if you've a battery issue or camera issue .
I think mine last half the time as they did new .
But still plenty of life in them to not need replacing , especially as I have quite a few spares.
One in my pocket gives me price of mind , though a charged up one's never ran out in a day .
Hopefully you just need a new battery .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Hike Pics
OP Hike Pics Senior Member • Posts: 2,917
Thanks Neil, you help is very much appreciated. When I got the camera 2 years ago it came with 2 batteries. One is the original OEM battery (800mAh), the other is a no-name brand (700mAh).
It looks like I used the camera back in April last year. I charged the newer battery just a couple of weeks ago.
I would try resetting the camera but I doubt it would stay on long enough to do that.
...Wes...
Hike Pics
I Think The Problem Has Been Solved
I noticed yesterday that a new Kastar battery from Ebay ($6.50US) reads "Limited Voltage : 8.4v". This got me curious as to what the voltage is on my batteries right off the charger.
I charged and checked the OEM battery and it read 8.52v. I put it in the camera and powered it on. The battery icon wasn't displayed until I metered down. It showed the full battery indicator. I charged the no-name battery and got 8.08v right off the charger.
So, the batteries charge a little higher than what is indicated on the battery. I don't know if that is a common thing or not. However, I'm going with my intuition and getting 2 new batteries. I think the old ones are ready to be replaced.
Thanks again Neil for your offer to help but I think you don't need to bother unless you are curious.
By the way, I have another 7i on its way. I don't even know if it will work or not, but it is coming with the power adapter. I paid very little for the camera.
...Wes...
neilt3
Re: I Think The Problem Has Been Solved
I'm just checking the batteries now .
The last time I used the camera was at the end of August ( this year !) .
Both batteries would have been charged recently around that time , but have been sat since .
The spare battery still has a voltage of 8.08 volt .
The one in the camera reads 7.59 volt .
The cameras battery indicator shows half charged and I had taken 22 photos on it that day .
I've cycled the flash a few times and reviewed the images and taken a few more just now , but the camera is still happily working and still shows a half charge .
But I wouldn't trust it to get me far on a day out without being charged up first .
Both batteries are original Minolta ones , so are at least 14 years old as Sony took over the imaging side in 2006 .
The voltage rated on the battery is 7.4 volt , but all batteries have a stated voltage much lower than they really are if they still have a good charge .
Take a reading from a new AA disposable battery . It's more than the 1.5 volt on the label .
Think about your 12 volt car battery . Much less than 12.8 volt and you might struggle to start your car in a morning .
Your alternator charges it at around 13.5 volt minimum , some are about 14 volt .
If your camera battery shows 7.4 volt , it's flat as a pancake , the one that showed 6.63 volt must have a bad cell in it and needs to go in for recycling !
I'm charging them both up and will see what the freshly charged surface voltage is , and then what it is after 24 hours .
Realistically , I'm probably due some new batteries myself .
Mine don't last anywhere near as they used to when I got the camera ten or twelve  years back , and that was charging them up reasonably often . A rechargeable battery allowed to drain flat and left seriously damages it .
Likewise running a batter flat and not charging it again ASAP damages as well .
I think your new ones will solve your problem .
neilt3
The 6 volt mains adapter your getting with the Dimage 7 will also run your A200 .
On another plus note , the internal battery / capacitor in my A200 had died as this camera hadn't been used for a while ( I have several ) and changing batteries needed the date and settings to be reset each time .
After being in regular use again this year , the internal one has made a recovery and I can change batteries without having to reset the camera !
Hike Pics
Many, many thanks Neil. Good info here. I know about a car battery's voltage, I just didn't realize a camera Lithium battery would be the same. It will be interesting to see what the new batteries charge at.
Indecently, I just checked the voltage on the generic HL-400 battery for my A2, it reads 8.10v and I can't remember when I charged it last. It's a 7.2v 1400mAh. The A2 is showing a Full Battery icon. But, since I don't know how old this battery is I might as well get a new one while I'm at it.
...Wes...
neilt3
The battery that had been in the camera has charged fully .
It was left in the charger for an extra hour after the light went out as some chargers give a final charge in this time .
The voltage now reads 8.27 volt .
The meter on the camera shows it as full .
Oh and the internal battery hasn't recovered . If the batteries out for more than a few minutes I had to reset the camera .
Changing the battery takes just a few seconds , so hasn't been a problem .
I will update the voltage in the morning , and the spare battery .
Edit 2 ;
Battery No 2 .
Fully charged and left in the charger for an extra hour ; 8.2 volt .
neilt3
The batteries for my A1 , a2 and Dynax 7d are also all original 14 year old+ Minolta batteries , so I've no idea how old they are , or the typical voltages of them , but they all hold a good charge .
So at least I know there good for a few more years .
Film or digital , when I go out with a camera I always have a spare battery with me anyway .
Regards battery voltage .
All batteries , including the coin type you put in a watch states a different voltage on it than the voltage actually in it .
I'm not sure what the stated voltage refers too , but it only seems to be about right when the battery is "dead" . Full batteries are always higher , regardless of chemistry .
neilt3
Edit 2 ;
Battery No 2 .
After being sat since last night after charging , both batteries now read 8.17 volt .
So the surface charge should have gone as they have settled down .
These batteries don't hold the charge that they used too so I don't get anywhere near the shots out of them that I use too .
It would be interesting to know what the voltage is on your new batteries both after they've charged and a day later after standing .
johnapp Regular Member • Posts: 423
Indecently, I just checked the voltage on the generic HL-400 battery for my A2, it reads 8.10v and I can't remember when I charged it last. It's a 7.2v 1400mAh. The A2 is showing a Full Battery icon. But, since I don't know how old this battery is I might as well get a new one while I'm at it.  TRY cleaning your contacts
