Grip for Z5?
Started 4 months ago | Questions
Sydcar New Member • Posts: 23
Grip for Z5?
OK, I'm just getting over the shock that there is no battery grip with vertical controls available for the Z6. But I can't find out if the grip that is available can also be used with the Z5? This is the only article I can find saying it does fit:
https://www.amateurphotographer.co.uk/reviews/compactsystemcameras/nikon-z5-review
I primarily would want this for handling/feel rather than battery life, so if it meant Dremelling off the bit that sticks out into the battery compartment, so be it, but obviously I'd rather not.
If you think this is weird, I currently use a Canon grip, also with strap that goes round my hand, from the 1980s screwed into the bottom of my Sony RX10 iv I just think it's a lot more comfortable and safe to hold and carry for long periods.
While I'm here as I try and decide between a D750 or Z5/6, does anyone know what FPS you can get on a Z5/6 with a shoe mounted flash running? My current camera slows from 24 fps to under 1 fps (excruciating and the main reason I'm selling) regardless of flash power output, 1/128 manual power, etc. Anything around 4fps and up with flash would be fine for me.
Thanks!
 Sydcar's gear list:Sydcar's gear list
Sony RX10 IV
Nikon D750 Nikon Z6 Sony RX10 IV
HeavyDuty Senior Member • Posts: 2,173
Re: Grip for Z5?
If you’re looking to add pinky space, the SmallRig plate works well.  I also have the Nikon MB-N10 which I only use in cold weather.
Ken in New Hampshire
Railroad Action: http://www.pbase.com/kjford
Candids: http://www.pbase.com/kjford/other
 HeavyDuty's gear list:HeavyDuty's gear list
Leica APO-Summicron-M 75mm f/2 ASPH Fujifilm X100S Canon XC10 Sigma dp0 Quattro Sony RX10 III +76 more
OP Sydcar New Member • Posts: 23
Re: Grip for Z5?
Good idea, I already have one of those for my RX10 and they do help a bit. I saw a video with someone using a Meike which seemed slightly deeper.
Sony RX10 IV
