EM-5 III display electronic level AND ISO?
pula58 Forum Member • Posts: 86
I have not figured out how to have the rear display show the electronic level AND the ISO (at the same time). Has anyone figured-out how to do this ? I can get one or the other (by cycling through the 4 different "info" views) , but not both at once.
Thanks!
P.
Bassam Guy Senior Member • Posts: 2,266
Re: EM-5 III display electronic level AND ISO?
Thanks!
P.
Just turned on my camera to see if I could help you and what did I see on the LCD? ISO and  Level! A miracle! Let me see how...
my exact settings, most will probably have no affect, I hope they help...
Menu -> Custom ->
Disp/PC
D1 Info Settings -> LV-Info
    [X] Image Only
    [  ] Custom1        -- I'm sure it would work if the Custom2 settings were applied to 1
    [X] Custom2
        [X] Histogram
        [  ] Highlights & Shadows
        [X] Level Gauge
D3 Grid Settings
    Apply Settings to EVF  On
EVF
I EVF Style 3
I Info Settings
    [X] Basic Information
    [X] Custom1
        [  ] Histogram
        [X] Highlight & Shadow
        [X] Level Gauge
    [  ] Custom2
Hmmm, I just discovered that, with EVF Style 3, the Custom1 settings aren't used but instead echo the LCD.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 II Olympus E-M5 III Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Helen
Helen Veteran Member • Posts: 7,522
Bassam Guy wrote:
Thanks!
P.
Menu -> Custom ->
Disp/PC
[X] Image Only
[X] Custom2
[X] Histogram
[X] Level Gauge
D3 Grid Settings
EVF
I EVF Style 3
I Info Settings
[X] Custom1
[ ] Histogram
[X] Level Gauge
[ ] Custom2
An interesting wrinkle to this is that whilst Auto ISO remains visible in the displays in combination with the level gauges, a fixed, manually-set ISO value will appear initially for a brief time, but then disappears (when the level gauges are on the display).
