Moon shot with Sigma sd Quattro H and a 135mm lens
furtle
furtle Senior Member • Posts: 1,225
You're no doubt all done with moon shots and seen every one but here's my effort as a newby to moon photos with an unusual camera for this sort of stuff.   It ws a nice crisp early eveining in the UK.  Bit of a stretch wih a 135mm lens, so, a lot of cropping!
Best, Steve
 furtle's gear list:furtle's gear list
Ricoh GR Digital III Sigma DP1s Sigma DP2 Merrill Sigma dp3 Quattro Sigma dp0 Quattro +9 more
Sigma sd Quattro H
DavidWright2010 Senior Member • Posts: 2,649
Re: Moon shot with Sigma sd Quattro H and a 135mm lens
I was going to congratulate you for a mighty effort with a tiny lens, but then I peeped a bit. Something has gone horribly wrong in the lower left:
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
furtle
OP furtle Senior Member • Posts: 1,225
David
Thanks, david. Yes, indeed. The image at 100% crop was passed through AI Gigapixel with a 1.5 'enlargement' and gentle noise and blur adjustment.
Below is a straight 100% crop without any AI Gigapixel. I think the mess on the bottom left is still there.  Maybe the lens?
screen grab of that area zoomed in.
Best, Steve
Alen K Senior Member • Posts: 1,134
David
Best, Steve
I think the "mess" is just pixelization due to insufficient resolution, no more or less. Here is almost the same phase with longer focal length (762mm):
https://cdn.astrobin.com/thumbs/smjMhGrVoBtC_16536x16536_xTjz_rdB.jpg
David
Best, Steve
Yes, it's still there.
I was unable to replicate your original result with resize in PS and then Topaz Sharpen AI (which I use often). But as you probably know, Sharpen can fail spectacularly if the noise is too high. Gigapixel probably has the same 'problem'. I've seen crazy 'details' in this area of the Moon on my own shots after AI-stabilize.
I think your lens and image are correct, though. It's just an unhappy result of undersampling complex terrain. I found a higher rez image (Sigma SD1M) of mine (one with a similar phase angle) and down-rezzed to your resolution. I think the details you have are in agreement with actual details.
You can look for yourself (my down-rezzed image on left):
David
furtle
David
Thanks, David.  It looks like I reached the limit of what a 135 mm lens and the Sigma sd Quattro can do.   I guess I need a longer lens but that's not a road I'm likely to take.
Best, Steve
