RX1Rii users: does the ZX1 look like an upgrade?
OP Digital Nigel Forum Pro • Posts: 13,503
Re: RX1Rii users: does the ZX1 look like an upgrade?
tbcass wrote:
JDLaing50 wrote:
Digital Nigel wrote:
JDLaing50 wrote:
I’m curious why you think a camera from a different manufacturer would be an upgrade for a Sony camera.
Why not? It's a newer, more expensive model in exactly the same niche. They even both have Zeiss-branded lenses with the same spec.
I bought a Sony RX10M3 as an upgrade on my Panasonic FZ1000, and an RX100M6 as an upgrade on my Panasonic TZ100 I bought a Canon G7X as an upgrade on my RX100.
It’s just flat not a Sony camera. A whole different approach. The lens is not the same spec. It was developed to match the Zeiss in house developed sensor. The Sony RXIRIII is a rehashed lens from the earlier cameras. I’ve used both and there is no comparison.
A camera does not need to have anything in common with another camera to be an upgrade. I am defining upgrade to mean any product that is superior to another.
I wonder who actually makes the ZX1?  As with the 'Zeiss' lens on the RX1, it's unlikely to be Zeiss itself.  It will be interesting if any reviews mention the country of manufacture. And I wonder if Sony makes the sensor?
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +19 more
JDLaing50 Senior Member • Posts: 2,351
It’s superior.
 JDLaing50's gear list:JDLaing50's gear list
Sony RX1R II Olympus PEN-F Leica M-P (Typ 240) Panasonic Lumix DC-S1R Voigtlander 50mm F1.5 Nokton +7 more
Zeiss makes it. It’s an in house Zeiss designed sensor. Designed in Germany assembled in China.
Made by Sony?
That reduces its value compared to actually making it in Germany.
It’s superior.
In what way?  The sensor is lower resolution and seems quite old in its specification. The lens also seems to have a cheaper, simpler design than the RX1 lens.
So, is there any area where it beats the RX1Rii?
It’s superior.
Many. And resolution at that level is not everything. It seems you’re one of the folks stuck in the pixel race for quantity and not quality.
It’s superior.
In what way is it better, then?  And surely an A7Riv with a 35mm f/1.8 lens would beat both of these cameras? Amazingly, it even has a smaller body, despite having much better controls, better AF, IBIS, EVF, etc!
It’s superior.
Image quality, features, file transfer, storage, screen, build quality, lens. IBIS is a crutch and not necessary. It has a far better evf.  Auto focus is better and more accurate.
sybersitizen Forum Pro • Posts: 19,300
... So, is there any area where it beats the RX1Rii?
I still have a couple of unanswered questions from earlier:
sybersitizen wrote:
What RX1RIII? Are you talking about the RX1RII?
You seem to be saying the lens for the RX1 series should have been redesigned when the sensor resolution changed from 24MP to 42MP. Is that your point?
You've used both what? You're saying you've used an RX1R model and the ZX1? How were you able to use the ZX1?
I was able to try it and test for a week. I own an RXIRII. To my earlier post I meant the II not III. The lens is different from the Sony camera. It has been redesigned for the Zeiss camera.
I'm sure the ZX1 lens design is different from the Sony lens design. Is it correct that you think the RX1 series lens should have been redesigned when the sensor resolution changed from 24MP to 42MP? Is that why you used the word rehashed?
Yes.
Yes, it's certainly a different lens:
RX1: Sonnar, 8 elements in 7 groups, including three aspherical elements
ZX1: Distagon, 8 elements in 5 groups, including two double-sided aspherical elements.
But which is better?  The Sony lens sounds like it's more expensive to make. And how do these lenses compare with the Sony FE 35/1.8 lens?
Tiffles Veteran Member • Posts: 5,042
Still on rx1r first gen - does its job
will go for an rx1rii once it falls apart
the Q2 is tempting but I‘d rather take a 24mm fixed lens sony tbh
 Tiffles's gear list:Tiffles's gear list
Sigma DP1 Sigma DP1 Merrill Sony RX1R Kodak DCS Pro 14n Nikon D700 +7 more
tbcass
tbcass Forum Pro • Posts: 48,554
JDLaing50 wrote:
It’s superior.
Not having used either camera all things said the RX1Rii seems superior to me.
Tom
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-300mm F/4-5.6 Di USD +7 more
tbcass wrote:
JDLaing50 wrote:
It’s superior.
I think what's amazing is the sheer bulk of the ZX1. The body is larger than the A7Riv, yet it has hardly any physical controls. An A7Riv with a suitable prime lens would be superior in just about every way to the ZX1, and well as smaller and much cheaper. For example, one could use the excellent FE 24mm f/1.4 G Master lens, or dozens of other prime and zoom lenses. Indeed, for the price of the ZX1, you could probably buy the A7Riv and a couple of very good prime lenses. That would be a far superior solution.
https://camerasize.com/compare/#826,806
tbcass wrote:
JDLaing50 wrote:
It’s superior.
The use of the word superior in this discussion comes down to personal judgment. Different cameras and camera systems almost always have both pros and cons, making one superior in some ways and inferior in other ways. And two different people looking at the same factor can consider it either superior or inferior.
If you like one overall for your use case more than you like the other overall for your use case, that's the one that's superior to you. There's not much else to say about it.
tbcass wrote:
JDLaing50 wrote:
It’s superior.
True, but I struggle to think of any single area where the ZX1 is superior to existing cameras on the market.
One thought occurs to me: maybe Zeiss had to create a new lens for the ZX1, as Sony almost certainly builds and owns the rights to the RX1 lens?
mike geier
mike geier Senior Member • Posts: 2,040
I agree, and the 7C does look very tempting
 mike geier's gear list:mike geier's gear list
Sony RX100 Sony RX1 Sony Cyber-shot DSC-HX50V Sony RX100 III Sony Cyber-shot DSC-HX80 +14 more
