My wives phone went black
Started Nov 26, 2020 | Discussions
Harvest2003 Forum Member • Posts: 77
I believe it is a Samsung J2, I was using the phone to make a call, when finished ended call and hit home button.  Phone went black, it has been on charger for awhile and this is the screen it gives when hitting on button while charging.  Any idea on the problem?  She goes through Total Wireless at Best Buy.
Nikon 1 J2
Robert Zanatta Senior Member • Posts: 2,630
Re: My wives phone went black
Looks like a charging for symbol.  Could be a moisture issue, a bad charger or cable issue, a software/firmware issue, a bad USB port, or a charging board issue.
Try removing the battery for 30 seconds and then put it back in.
Try different cable and charger.
Try cleaning the USB port with alcohol and then blow it out with compressed air.
If that doesn't work then try a hard reset and maybe wipe the cache.
 Robert Zanatta's gear list:Robert Zanatta's gear list
Canon EOS 5D Mark IV
I2K4
I2K4 Senior Member • Posts: 1,441
No experience with that phone but often use Android Recovery Mode when A phone or tablet has a problem (or even just slows down.) Once charged, or on a charger cable, restart the phone using hardware key sequence shown. Best to first try "wipe cache partition" because it flushes and rebuilds the system cache without deleting anything or changing any settings - navigate using the hardware Vol buttons and select using the Power button. On devices that support it, I do Recovery Mode cache wipes every few months or when noticing any operational issues.
Hard reset ("wipe data / factory reset") is a last resort because it restores the device to "out of the box" configuration and preinstalled apps, deleting everything else. If there's important personal data, photos, etc. on the phone not backed up elsewhere (why the heck not?) try to connect the phone to a PC to extract and save what you can. Also requires logging back in to the same Google Account (be sure to know how) to activate the device afresh.
The above is standard Android, while I think some Samsung models have extra diagnostic and recovery software and support manuals online.  Does look like a hardware problem from the charging screen shown.
Good idea to independently double-check and confirm for the specific phone.  Good luck.
Eddie Rizk Senior Member • Posts: 1,224
How many wives do you have?
That's my opinion, and it's worth what you paid for it.
Eddie Rizk
The race is not always to the swift nor the battle to the strong, but that's the way to bet.
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
OP Harvest2003 Forum Member • Posts: 77
Phone eventually corrected itself after a few hrs.  For a cheap phone I'm not surprised.
ernstbk
ernstbk Veteran Member • Posts: 3,177
Quite interesting that this cheap phone has a feature to tell the user that the device getting very warm and that as a precaution the power cable should be removed.
Must have been a very long phone call.
 ernstbk's gear list:ernstbk's gear list
Panasonic Lumix DMC-FZ20 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-G3 Panasonic Lumix DMC-GH3 +29 more
(unknown member) Forum Pro • Posts: 12,611
It’s telling you the internal temp is too high . Allow phone time to cool down and clean battery contacts in case that’s what’s causing the issue with a poor connection during charging.
He worships me so much he even took my name. How awesome is that!
Ben Roubin Regular Member • Posts: 186
I was wondering that too. Maybe he's from Utah.
mbr
 Ben Roubin's gear list:Ben Roubin's gear list
Canon PowerShot A650 IS Apple iPhone 4S
Wayne Larmon Forum Pro • Posts: 10,694
Is the battery swollen?
Does the phone or battery look at all bulged? If so then this is a sign of a swollen battery and this is very bad.
I recently went through a round of swollen batterywith a tablet. I was able to replace the battery with no problems but I just took a close look at my Pixel 2 and I am not happy to see that the screen is starting to bulge out. The Pixel 2 battery isn't really user replaceable (lots of glue that requires heat and volatile solvents), so I'm suddenly in the market for a new phone.
Be very wary of swollen batteries.
Wayne
