DSS stacker
Started 4 months ago | Questions
jasonm10 Regular Member • Posts: 173
DSS stacker
New to DSS. Is the program really able to process Sigma X3F raw or is it just going through the motions and I need to save as something else. Tried to use saved X3F files, not x3f/jpg combined files. Had 98 lights, 30 darks, 30 bias for test. No flats.
thx.
JeffSlade
JeffSlade Regular Member • Posts: 496
Re: DSS stacker
thx.
You might want to do a post at Cloudy Nights as well if you have not done so already.
https://www.cloudynights.com/
I've found an old thread in DPReview from 2015 where there was an issue. That's along time ago.
I will use DSS for the first time today but I'm using Canon so should be no issue with raw file type.
Here is the DSS manual if you do not already have it.
http://deepskystacker.free.fr/english/userguide.htm
I believe in wabi-sabi : a world view centered on the acceptance of transience and imperfection. I appreciate beauty that is "imperfect, impermanent, and incomplete" in nature.
https://www.flickr.com/photos/billpoplawski/albums/with/72157716942456506
https://www.youtube.com/c/twelfthavenuecuisine
 JeffSlade's gear list:JeffSlade's gear list
Canon EOS 6D Fujifilm X-T1 GoPro Hero7 Black Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM +7 more
Astrozoid
Astrozoid Contributing Member • Posts: 846
Re: DSS stacker
Do you have the latest version of DSS?
You absolutely need to save files out of your camera with the RAW format, not jpegs.
Here are tips on using DSS.
If your files won't work, just convert them with Adobe's free DNG converter. Those will work in DSS.
Jerry
swimswithtrout Veteran Member • Posts: 3,777
Re: DSS stacker
Jerry
I'm not sure that even the DNG convertor can handle the Sigma files.
Astrozoid
Re: DSS stacker
Jerry
I am too lazy to check, but it handles everything else I've ever heard of.
Not saying you are wrong.
Jerry
OP jasonm10 Regular Member • Posts: 173
Re: DSS stacker
JeffSlade wrote:
thx.
Thank you.
Re: DSS stacker
Jerry
Thanks. Still Sigmas proprietary raw x3f files. The sigma camera's  now allow to shoot in DNG which regrettably I did not do.
SigmaChrome Forum Pro • Posts: 13,182
Re: DSS stacker
thx.
Which Sigma camera did you use, Jason?
I believe Sequator can use .TIF files. If you develop your X3F files in Sigma Photo Pro and then export them as 16bit TIFs, you should be OK. Sequator is a free download.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma dp0 Quattro +36 more
Re: DSS stacker
I have a SDq.
But I need to go online and update all the firmware for the body as well as the dock and lenses. I have to remember and write the len settings from the dock as the hours I spent matching the lenses to the body were very tedious, but highly successful.
With updates I always go with the assumption that everything could be written over.
I have to do this this week before the saturn conjunction.
I'm probably going to shoot all DNG as well. The last update of firmware opened this benefit up. Hopefully these programs work with DNG. Photoshop seems to work with Canon or camera raw and DNG but not sigma DNG.
C'mon Sigma.
