Cable for 7D Mark II to Macbook
tedwill48167 Contributing Member • Posts: 810
Hello.
I'm looking for suggestions for a cable to connect my 7D Mark II to my new Macbook with USB-C connectors only.  I'm having a hard time finding the Mini HDMI to USB-C connectors.
Thanks!
-Ted
'There are no rules for good photographs, there are only good photographs.'
-Ansel Adams
 tedwill48167's gear list:tedwill48167's gear list
Canon EOS 7D Mark II Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L USM Canon EF 24-70mm f/2.8L USM +2 more
Boomanbb
Boomanbb Veteran Member • Posts: 3,001
Re: Cable for 7D Mark II to Macbook
You cannot directly connect your hdmi to a computer without going thru a hdmi capture device
You can connect the camera via usb 3.0 for tethering purposes.
Ben Boozer
Disagree without being disagreeable
 Boomanbb's gear list:Boomanbb's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EOS M3 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm f/2.8L USM +12 more
S Castle
S Castle Senior Member • Posts: 1,103
Yeah, I wondered if he just mistyped, and meant USB instead of HDMI. Or as you say, perhaps he is misinformed.
Shane
OP tedwill48167 Contributing Member • Posts: 810
I did mistype.  Thanks for catching that.  What tether works best?  I have had a hard time finding one.
Thanks!
-Ansel Adams
Boomanbb
I picked up a 6' right angle usb cord for my 7DMKII on Amazon, make sure you get the correct right angle so that the cord hangs down. I am using the usb a connection on my laptop. If I wanted to use the usb c connection I would get something like this:
https://www.amazon.com/Cable-Matters-Type-C-Micro-USB-C/dp/B00UUBQ710
Also, since you have a macbook you are likely to have an iPad. Are you aware that the app Cascable has wired tethering to your camera? It works like a dream and I much prefer it to tethering to a laptop. You can control camera functions, add cool new things like bracketing, intervalometer, download raw from the camera, etc.
Ben Boozer
This is very helpful thank you. What was confusing to me was that the 7d Mark II's manual indicates that the out connector is "HDMI Mini", but in this case, I need the Micro USB to USB-C to connect to my MacBook.
I'll check out the iPad tethering app too.
Thanks!
-Ted
-Ansel Adams
It worked like a charm!  Thanks for your help!
-Ansel Adams
