Lightroom: How to invert a range mask?
Henry Richardson Forum Pro • Posts: 18,817
I am using the latest LrC 10.0.  I can't find a way to invert a range mask.  Is there a way?
Henry Richardson
http://www.bakubo.com
Ernie Misner
Ernie Misner Veteran Member • Posts: 7,216
Re: Lightroom: How to invert a range mask?
I don't see anything specifically for the range mask feature for inverting there.  What I am seeing is you can invert a selection made with the radial filter by ticking the "invert" box.  And the range mask does work with the radial filter.  No invert option for the brush or grad filter that I am finding.
Ernie Misner
http://www.flickr.com/photos/erniemisner/
The first digital image was made in the late '60's for NASA, as a way to record images of Mars. Each "square" was represented by three numbers, corresponding to the red, green, and blue hue on a scale of 0 to 255. This eliminated the need to ship film back to Earth.
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon Z6 Nikon AF-S 70-200mm F2.8E FL ED VR Nikon Z 24-70mm F4 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED +6 more
kaphinga
kaphinga Senior Member • Posts: 2,848
Just thinking out loud ... could you make the adjustments over the whole image and then use the range mask to pull back your adjustments? It's not the ideal solution, but it ought to work.
Marie
 kaphinga's gear list:kaphinga's gear list
Nikon D750 Olympus E-M5 II Olympus E-M5 III Nikon AF-S Nikkor 50mm F1.4G Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +17 more
OP Henry Richardson Forum Pro • Posts: 18,817
I just checked and see that you are right that there is an invert option for the radial filter.  It is very strange that it not available for the graduated filter also.
Henry Richardson
dj_paige
dj_paige Senior Member • Posts: 2,320
Make a feature request to Adobe. https://feedback.photoshop.com/topics/lightroom-classic/5f5f2093785c1f1e6cc40872
Paige Miller
I will play around with that to see if it will work.  Thanks.
Henry Richardson
Okay, I just submitted a request.  I find it very strange that they added an invert option for the radial filter range mask, but not the graduated filter and adjustment brush range masks.  I hope they will add it to all 3.
Henry Richardson
dj_paige
Yes you could, I experimented with this and it appears to work.
Paige Miller
RussC
RussC Regular Member • Posts: 338
It is, in a way. If you apply a graduated filter to the entire image (eg. select grad filter, click on bottom corner of image and pull off the image) then you can use the range mask eye dropper tool on different parts of the image to select a given color or luminance, and that will provide the mask. Not strictly an invert, but in the luminosity option you can click through each luminosity grayscale and select the one you want to mask. Same with the color mask.
RussC
 RussC's gear list:RussC's gear list
Canon PowerShot SD1000 Panasonic Lumix DMC-LX3 Panasonic FZ1000 +2 more
Ernie Misner
Thank you for doing that Henry and please keep us posted if you get a reply or reason from Adobe.
Ernie Misner
dj_paige
As far as I know, Adobe rarely gives a reason for their decisions. They do reply with possible workarounds, or they reply that this will be added to their list of things to work on.
Paige Miller
Here it is:
https://feedback.photoshop.com/conversations/lightroom-classic/lrc-add-invert-option-for-range-masks/5fbed610ce4ce1357af21add
Henry Richardson
ppage
ppage Senior Member • Posts: 2,109
Just so we don't get too confused here... there is no invert option for the radial filter range mask.  There IS an invert function for the filter itself, but not for its range mask.
Brandon birder Veteran Member • Posts: 4,759
RussC
This is what I do too. It would be easier with an invert mask control but that would only work for two sets of tone ranges. The way RussC uses and the way I use them allows me to quickly set up any number of luminosity brush ranges like in luminosity masking only inverted..
Cheers, Brandon.
Olympus EM1mIII, EM10 mII, Sony RX10 M4, RX100 M7
Nikon V1,V3, D500, D810
FlickR Photostream
http://www.flickr.com/photos/brandon_birder/
 Brandon birder's gear list:Brandon birder's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-100mm F4.0 +1 more
mfinley
mfinley Senior Member • Posts: 4,802
Why would there be an invert to the graduated filter and the brush?
To invert the graduated filter just apply it to the opposite part of the image.
The brush is to paint an effect to a specific subject not to everything else but that subject. To do that you would apply a radial filter and then use the brush on erase mode to mask that subject out of the radial filter. That would be an inverse brush.
 mfinley's gear list:mfinley's gear list
Olympus 7-14mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0
