EOS Webcam Utility not working
nemike New Member • Posts: 2
I have a Canon 7D and I downloaded the Webcam Utility for my Mac.  When I go to zoom and select the EOS Webcam Utility as my "Camera" I get a backward image saying "EOS Webcam Utility" and a icon that looks like a camera and a red triangle with an exclamation mark instead of any video from my 7D.  I've tried starting live view etc, nothing works.  Any ideas?
Thanks, Mike
Canon EOS 7D
S Castle
S Castle Senior Member • Posts: 1,108
Re: EOS Webcam Utility not working
You don't say what OS. There's a matrix of supported and unsupported OS/app combinations on the Mac FAQ.
Zoom is listed as supported in all of them, though.
You might have a USB cable that's not supported, or has a problem. You have to exit the Canon EOS Utility, if it starts up automatically, as it does on my Windows systems. On my systems, I also need to move the live view/movie selector switch to 'movie' or it does not behave correctly.
Canon really has done a poor job providing information about how to use the webcam utility. Apparently they think it should just work for you.
I hope you get your problem sorted.
Edit: I experimented with mine a little, and if I don't quit the EOS Utility and try to connect to the streamed camera, I get the red triangle with bang also, so I suspect that is your problem -- you must quit the EOS Utility. Or perhaps there's something else trying to communicate with the camera?
Shane
OP nemike New Member • Posts: 2
Sorry my mac is a Mac Pro 2010 with 24 cores @ 3.46ghz 128gb of ram and it's running Mojave.
I have a bag of about 20-30 MiniUSB cables, I have tried a couple just in case, when I plug the cable into the camera the EOS Utility window appears:
Thanks me too...
I've tried exiting the EOS Utility window after connecting the cable, I've also tried killing the background process /Applications/Canon Utilities/EOS Utility/EOS Utility.app/Contents/MacOS/EOS Utility still nothing changes, when I disconnect the usb cable the webcam looks like this:
When I connect the cable I just get this:
I've tried putting it Movie mode after and before connecting the USB cable, I've tried connecting the USB cable while the camera is off and then turning it on, etc etc.  So far nothing has changed.
I do have the "latest" firmware installed 2.0.6
Thanks for the help!
Mike
davinci953 Regular Member • Posts: 390
Thanks, Mike
Check the information for your OS at the following link. Maybe there is something that can help get the issue sorted out. There is also a Canon support forum for the webcam utility.
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/eos-webcam-utility/
S Castle
I understand that MacOS is Unix underneath, and the lsof command works in a terminal window. You could use that to determine what has the camera device open, if anything. Also, note that the Canon EOS Utility will start up by preference and you must quit out of it before the streaming utility can work.
Shane
