How to clean the black coating at the rear side of the lens
Started 4 months ago | Questions
patheon New Member • Posts: 1
Hi,
Recently when I cleaned my read side of the lens, I used a wet wipe to wipe the black coating (non on the glass) at the rear side of the lens (see picture below). However, a lot of fluff / hair comes from the coating. Does anyone know how to deal with that? Thanks!
Walt Palmer
Walt Palmer Senior Member • Posts: 1,918
Re: How to clean the black coating at the rear side of the lens
patheon wrote:
Hi,
Microfiber lens cloth, often known as "Magic Cloth" that seems to come with every other online photography purchase. Try it dry first, moisten, slightly, if needed. It leaves no residue.
-- thus saith Walter ("Who?") Palmer, Ctr
Walt Palmer
DON'T PANIC!!
Don't use high pressure air (seriously).
Don't use high pressure water (less so).
Don't use the new Dremel tool you just bought.
Don't moisten your finger tip (why not?)
Don't use flat black plastic model paint to cover it.
Don't let the partner or the offspring help.
Don't drink and play with camera gear (ever again).
Don't ask us, you put it there
-- thus saith Walter ("Who?") Palmer, Ctr, bdr
sybersitizen Forum Pro • Posts: 19,054
5
patheon wrote:
... a lot of fluff / hair comes from the coating. Does anyone know how to deal with that?
Try holding some ordinary cellophane tape against it. Loose fluff should stick to the tape so it can be removed.
FrancoD Forum Pro • Posts: 14,054
masking tape (the type used by house painters) is ideal. Press it on and peel off.
otherwise if you have some low grade sticky tape , use that.
(at work I used Scotch Magic Tape . I even cleaned mirrors with that )
