New to MFT and need lens advice
Started Nov 24, 2020 | Discussions
CJackJr
CJackJr Contributing Member • Posts: 962
Hi all,
I've been an Olympus 43 owner for many years (see my gear list) and a member of the Olympus SLR forum (although I haven't posted for a while). I recently purchased a Panasonic GX7 with a Lumix G Vario 12-32 lens. I'm quite happy with it and now MUST add to my lens collection. Being new to MFT I have a few questions:
  1. Is it worth getting a 43-MFT adapter to use my Oly FT lenses on the GX7? If so, any recommendations?
  2. Is there a benefit to sticking with Panasonic MFT glass on a Panasonic camera or do Oly (and other manufacturers) lenses work just fine?
  3. Even though I have the 12-32, I'm considering the 12-60 as my "walk-around" lens. (I have used the Oly 12-60 on my 43 gear and really liked its range.) Any thoughts on which 12-60?
  4. Lastly, I'd like something longer than the 12-60 to use occasionally for wildlife and candid photos of my grandkids playing. I've been looking at the Lumix 45-175. Any thoughts on that lens or anything else I should consider that is in that general price range?
I'll really appreciate any and all responses to even just one of my questions. I know from past experience that members of these forums have a wealth of valuable information and are more than willing to share advice/opinions. Thanks in advance.
Regards, Conrad
 CJackJr's gear list:CJackJr's gear list
Olympus E-1 Olympus E-520 Olympus E-30 Olympus E-600 Panasonic Lumix DMC-GX7 +10 more
Bassam Guy Veteran Member • Posts: 4,885
Re: New to MFT and need lens advice
CJackJr wrote:
Hi all,
Probably depends on which lenses you have. Perhaps listing them might inform those who are smarter than me.
  1. Is there a benefit to sticking with Panasonic MFT glass on a Panasonic camera or do Oly (and other manufacturers) lenses work just fine?
There is little benefit except in some longer focal lengths: dual focus will not work if brands are crossed, and viability of cross-brand weather sealing is unknown.
  1. Even though I have the 12-32, I'm considering the 12-60 as my "walk-around" lens. (I have used the Oly 12-60 on my 43 gear and really liked its range.) Any thoughts on which 12-60?
The 2.8-4 is generally considered better but it is bigger and heavier. There are plenty of threads on this topic in this forum as both are popular. If you don't mind the size and less snappy AF, perhaps adapting the 43 lens might suffice.
  1. Lastly, I'd like something longer than the 12-60 to use occasionally for wildlife and candid photos of my grandkids playing. I've been looking at the Lumix 45-175. Any thoughts on that lens or anything else I should consider that is in that general price range?
Seems like a good choice. If you're short on cash, the Olympus 40-150 4-5.6 has excellent image quality for $99 new, hence the "plastic fantastic" nickname.
Thank you, we strive to be practically perfect in every way. We never fight and we're always polite
Regards, Conrad
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
dlevitt Senior Member • Posts: 1,187
CJackJr wrote:
Hi all,
Regards, Conrad
1 - They likely will focus slower on the GX7. These lenses were not designed/optimized for contrast detect autofocus [or the DFD enhanced version]
2. Some features [dual IS; DFD focus; focus stacking...] require matched body and lens brands.
3. You probably would be happier without the adapter for the 'walk around' normal, so the choice would be mostly between the Panasonic and Panasonic / Leica flavors of the lens.
4. An alternate might be one of the travel zoom lenses, again favoring Panasonic, with in lens image stabilization .
Save the Earth! Collect the entire set!
 dlevitt's gear list:dlevitt's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-LX7 Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
Skeeterbytes Forum Pro • Posts: 23,184
CJackJr wrote:
Hi all,
Depends on which lenses. Certain 4/3 lenses are CDAF capable--primarily the standard grade ones--but the rest really need a PDAF Oly to focus well, and will be poor on a GX7.
All are fully interchangeable. OIS Oly lenses are rare so IBIS is needed to stabilize them (don't know if your camera has it). Everything else should work normally regardless of brand.
Both have their fans. I'd opt for the faster PL one, myself. I have the Oly 12-40 and 12-100, both are excellent too, and constant-aperture.
So many choices. I'd be tempted by the 50-200, which looks excellent.
Regards, Conrad
Enjoy your new kit!
Rick
ahaslett
ahaslett Forum Pro • Posts: 12,654
With your FT lens list, I’d buy an adapter and a used EM1.1 or give up on your FT lenses.  The 50/2 might still be useful as an MF lens.  If your 14-54 is mk II it might work OK on a Panasonic body.  My 14-54 mk I works fine on EM1.1 and better on an EM1.2.  Never had a 70-300.  The 9-18 FT lens works on my GM1, as it’s CDAF optimised.  Not my favourite lens, but it does the job.  There seems to quite a bit of copy variation in the M.Zuiko version.
I gave up on my 12-60 SWD when the cable went for a second time.  I really loved the lens but I’m not sure either of the Panasonic lenses will match my copy, which was really strong at the tele end, whereas my 14-54 is best at the wide end and the 12-40 doesn’t have a tele end.  I decided to stick with the 14-54.
I use my 50-20 SWD which works as well on an EM1.2 as it did on an E30, although with better IQ.  The Panasonic equivalent is a really great lens but expensive.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
jalywol
jalywol Forum Pro • Posts: 12,301
CJackJr wrote:
Hi all,
As others have said, many of the lenses will be slow to focus, as they are not optimized for CDAF.
The advantage to Panasonic lenses on that body is in the IS area.  Most Oly lenses do not have OIS, which is fine when you are using one of the Oly bodies, as starting with the EM5, they had the 5-axis IBIS, but on the GX7, the IBIS is definitely not of the same level as that on the Olys.  So, since most of the Panasonic lenses have OIS, they will be a better match for that body.
Either the PL 12-60mm or the Panasonic 12-60.  The PL is faster, larger, and more expensive; the 12-60mm is going to give you IQ that is much more similar to the 12-32mm (which is a very good kit lens, but still a kit lens).  Your choice; depends on what you plan to use it for.
You have to be a little careful with that lens, as it's prone to shutter shock when using the mechanical shutter with that body.  In general, using e-shutter is the way to go with the GX7, as Panasonic didn't modify its shutter design until the GX85 to minimize SS when using the mechanical shutter.  However, some lenses are more sensitive to it than others, and that particular one is a bit touchy in that area.
You might want to look at the Panasonic 45-150mm f4-5.6 (which has OIS), or the very good, and cheap, Oly 40-150mm f4-5.6.  The Oly is the rare bird that has excellent output even though it's a cheap and plastic-y lens, but again, it does not have OIS, so it might limit you a bit.  If you want to go to the other end of the spectrum, the PL 50-200mm f2.8-4 is just fantastic, but it's expensive.
Hope this helps!
-J
CJackJr
OP CJackJr Contributing Member • Posts: 962
Thank you all for the sage advice, it was very helpful.
I think for now I'll just start with getting the Panasonic 12-60 and spend some time learning the camera. Probably follow that with one of the telephotos (would love the PL 50-200 but need to save up for that) and maybe the 30 macro.
As for my Oly 43 glass, I'll just keep using it on my E-1 and E-30 and skip the adapter.
I'll keep following the discussion on the board and perhaps post some photos.
Regards, Conrad
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
At least for now, you might consider pairing your 12/32 with Panasonic's similarly small 35/100...
https://www.imaging-resource.com/lenses/panasonic/35-100mm-f4-5.6-mega-ois-lumix-g-x-vario/review/
... for a combination that's about the same weight as their cheaper 12/60 option.
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
alcelc
alcelc Forum Pro • Posts: 19,003
CJackJr wrote:
Hi all,
All Pannys use CDAF (later model also DFD). AFAIK there are some CDAF optimised FT lenses that could be workable on Panny M43, but AF speed should not be fad from the lighting instant AF speed on using M43 lenses. Others PDAF based FT lenses could expect a very slow or haunting AF...
Not really, specially the older GX7 does not support DFD, that until now only Panny lenses are DFD compatible.
Having said that, since the IBIS of GX7 is very primitive (the first Panny to have IBIS) and its 0.5~1 stop effective IS would be just better than nothing. Since most Panny zoom lenses are OIS (3~3.5 stops), could be better than non OIS (majority) Olympus lens.
I heard on IQ both 12~32 & 12~60 (including the PL f/2.8-4 version) should be very close.
If you use a WR body, e.g. G85, G95, G9, GH5 etc, the WR 12~60 could give you a WR setup. Since GXs are not WR, this might do no extra good to you.
Might also consider the 45~150. They are in similar price tag, so do IQ. 45~175 uses internal zoom that might appeal to some people. I finally settled on 45~150 because of its smaller size on parking position.
Regards, Conrad
Albert
** Please feel free to download the original image I posted here and edit it as you like **
alcelc
Bassam Guy wrote:
CJackJr wrote:
Hi all,
But it is not OIS?
The 0.5~1 stop effective IBIS of GX7 & Oly 40~150 might not be the best option. I might pay US$20~30 more for the Panny 45~250 or 45~175. Both could expect 3+ stops effective IS on GX7, and if OP will upgarde to a later Panny later, could enjoy DUAL IS or DUAL IS-2 for another 1~1.5 stop of effective IS.
Regards, Conrad
Albert
alcelc
dlevitt wrote:
CJackJr wrote:
Hi all,
Regards, Conrad
AFAIK, most native M43 lenses would support Panny's version of in-camera focus stacking ( Post Focus) or any of the 4 bracketing modes including focus bracketing. Panny bodies will make use the AF feature of the lens. It is done differently from Olympus.
However, GX7 is not DUAL IS, nor DFD compatible. Since it is not 4K ready, it does not support Post Focus as well. There is only 1 bracketing mode (Exposure) on GX7...
Indeed Olympus M43 lenses also 😀, except for the IS because the IBIS of GX7 is merely nothing.
Albert
alcelc wrote:
Bassam Guy wrote:
CJackJr wrote:
Hi all,
But it is not OIS?
Interesting, never knew that the GX7 was so IBIS challenged.
Regards, Conrad
CJackJr
Peter
Hmmm, good point. I may consider that option. Thanks.
alcelc
Bassam Guy wrote:
alcelc wrote:
Bassam Guy wrote:
CJackJr wrote:
Hi all,
But it is not OIS?
What would we expect for the first IBIS body of Panny?
IIRC some members rated the IBIS of GX7 close to the IBIS of the earliest Olympus...
Except for G9, the IBIS of Panny's GX and G are still not as powerful as its eq class Olympus bodies. e.g. the GX85 or GX9, IBIS should be around 2+ stops top which is behind that of EM10 class of models. So are the G85/G95 which is 0.5~1 more stop effective IBIS than GX (largely because of its improved ergonomic), but still not as effective as EM5 class.
Therefore Panny needs DUAL IS to rival Olympus on this department. Fortunately, Panny does not short of DUAL IS lenses... Hence, there are always more restrictions on lens selection on Panny bodies than Olympus bodies.
Regards, Conrad
Albert
CJackJr
This is what I love about DPReview forums. Ask a few questions and then sit back and get educated. Thanks folks. But don't let me interrupt you.
Another lesson:
The Olympus 60mm is the longest and most popular Micro Four Thirds macro lens. Many start with one of the 30's (Panasonic or Olympus) and end up with the 60. You get more working room for more lighting options, less lens shade, and fewer scared insects flying off or running away. And, it works double duty as an excellent portrait lens.
New, it is $399. Used, I guess, should be comparable to a new 30.
Sorry, nothing political, just a celebrity
View: original size
john isaacs Veteran Member • Posts: 8,442
CJackJr wrote:
Hi all,
Regards, Conrad
1. No.  You need PDAF autofocus to make good use of 4/3 lenses.  And they are very large and heavy (although fast), which is counter to the m43 ethos.
2 Olympus lenses work well enough; although you don't get the dual IS.  Note that Panasonic and Olympus zoom rings rotate in opposite directions.  But many Olympus lenses have a manual focus clutch with repeatable focus so IF you shoot video and IF you pull focus, that's a benefit.  But Olympus PRO lenses are usually much heavier than comparable Panasonic lenses.
3. I like the 12-60 range, used to have the 4/3 version.  I don't have the Panasonic lenses (but I do like the Nikon 24-120 f/4 a lot).  I prefer the faster lenses, but I shoot in low light a lot.  If you don't, get the Panasonic Lumix version.
4. The 45-175 is an interesting lens; it is internal zoom, but also electronic zoom.  I use it when I need remote control.  Otherwise, my advice would be to just get the Pansonic 14-140 and look to longer telephoto options (like the 100-300 or 100-400) for wildlife.
I had a lot of 4/3 lenses.  They were too large/heavy and slow to focus, so I traded them in on Nikon gear.  I do have a lot of m43 lenses; they are lighter and faster to focus.  These are my primary concerns with m43 system.
CJackJr
John,
Thanks for the advice, it reinforces what others have said and gives me a better idea of how to proceed. I did pull the pin and purchased a Lumix 12-60 and look forward to using it and learn more about the camera. I'll wait a while and give some more thought about what long zoom I might want to purchase.
One thing that's pretty clear from all the comments is not to waste time and money on an adapter for my 43 lenses. I don't plan on getting rid of them but will just continue to use them on my 43 cameras. I do love the 50 f2 and will keep that on my E-30 and I can't help but love the images I still get from my E-1. Low light and quick focus haven't really been an issue for me. (The E-520 and E-600 with kit lenses will probably get handed down to the grandkids to learn the basics of photography.)
Hope you have a nice Thanksgiving.
Regards, Conrad
I'll make a pitch that an adapter for the 50 macro warrants pursuing on a new 20MP camera, the 14-54 may warrant keeping in play as well. Focus speed (which the 50 lacks on a good day) isn't super important with macro, although it does make a good portrait lens too.
Rick
CJackJr
Good points, thanks.
