Tamron Still Believes in APS-C
Started Nov 24, 2020 | Discussions
thunder storm Senior Member • Posts: 7,705
Re: Tamron is leaving $ MONEY $ on the table not making EF-M, Fuji-X lens
Microprism wrote:
Tthunder storm wrote:
Microprism wrote:
nnowak wrote:
Microprism wrote:
nnowak wrote:
Microprism wrote:
Athunder storm wrote:
Microprism wrote:
nnowak wrote:
Microprism wrote:
nnowak wrote:
ihgold2 wrote:
dwfrommonterey wrote:
Not everyone care to upgrade to Fullframe, majority of "consumer" don't want to spend $2000 when an $500~$1000 APS-C DSLR or Mirrorless will do.
Canon RP with decent kit lens $999. Right now.
That's a really tempting offer. Do you think f/7.1 is limiting though, in that kit lens? IQ notwithstanding, seems like f/7.1 being the largest possible aperture would be frustrating. What does everyone think?
f/7.1 on full frame is equivalent to f/4.5 on Canon APS-C crop. Yes, f/7.1 sounds slow, but when you consider that an equivalent EF-M lens would need to be 15-66mm f/2.5-4.5, f/7.1 suddenly looks pretty good. Going the other way, the EF-M 15-45mm f/3.5-6.3 is equivalent to a full frame 24-72mm f/5.6-10. After converting for equivalence, the EF-M 15-45mm ends up a full stop slower than the RF 24-105mm f/4-7.1.
No, f/7.1 is not ideal for low light use, but it is still better than any of the existing EF-M zooms.
It is really slow in low light when your subject is moving and you need a faster shutter speed.
For the same noise levels, you will still get a faster shutter speed with the RF 24-105mm f/4-7.1 than any EF-M zoom.
I don't think noise and exposure level are interchangeable for most photographers, but suit yourself.
Fake response.
How about a real response then? I don't remember
You should remember someone posting this:
https://www.dpreview.com/forums/thread/4535021/64597977
anyone ever posting, "Hey, that's great shot. Look at that low noise. Too bad the bird is a blur." If your subject is in motion you need a faster shutter speed to stop the motion unless you like blur. A faster lens allows that.
It's simply nonsense to state a faster lens is the only factor allowing for that. It can also be a higher ISO with a sensor with a better signal to noise ratio.
You either get the shot, or you don't.
You either understand how to adjust your ISO or you don't. You either understand the sensor signal to noise ratio performance is a factor just as important or you don't.
Suit yourself.
I know quite well that no matter how good a sensor is there is some light level at which either you use a faster lens or you get distractingly visible noise. The better the sensor the lower the light level in which it performs acceptably, but that threshold always exists. For myself, I know exactly what ISO level on my own cameras is acceptable to me. That suits me fine.
That is exactly the point. The 24-105mm f/4-7.1 on full frame will give you a higher threshold than any EF-M zoom on crop.
If I follow you correctly
nope
a full frame camera with a 105mm f/7.1 FF lens will produce an image with equivalent noise level to 66mm f/4.5 lens on a APS-C camera, correct?
not exactly
I think I got it, but here's the rub. If the correct exposure is f/4.5 and the actual exposure is f/7.1, the result is an underexposed image. So, next you take the full frame photo and go into your image editing program to brighten it accordingly. However, because the image was underexposed originally you have sacrificed an f/stop or more of dynamic range in order to compensate for the underexposure. So, yes, the 100mm FF f/7/1 setup has yielded an image with the noise level of a APS-C f/4.5 camera and lens combination. But it is one with less dynamic range. There is no free lunch in my experience. Of course, if f/7.1 is the correct exposure you are in great shape.
Let's back up. First, we need to clarify that we are talking about sensors from the same technological generation. No original 5D vs M6 II. Based on the differences in sensor size/area between full frame and Canon APS-C, we have the following....
  • At the same ISO setting, a full frame sensor will have 1 and 1/3 stops lower noise
  • At the same ISO setting, a full frame sensor will have 1 and 1/3 stops more dynamic range.
  • At the same aperture setting, the full frame sensor will have 1 and 1/3 stops shallower depth of field.
ISO 2500 on a Canon crop camera will have the same noise levels and same dynamic range as ISO 6400 on the full frame sensor. An aperture of f/4.5 on crop yields the same depth of field as f/7.1 on full frame.
An exposure of f/7.1, ISO 6400, and 1/100 on full frame versus f/4.5, ISO 2500, and 1/100 on crop will produce images with the same noise levels, the same dynamic range, the same depth of field, and the same subject motion blur.
The fastest zooms for the M system are f/5.6 at the long end. Lets say you are at f/5.6, ISO 3200 and 1/100 with a crop camera. At f/7.1 and 1/100 on the full frame camera, you would need to be at ISO 5000 for the correct exposure. ISO 5000 is 2/3 of a stop above ISO 3200. Given the 1 and 1/3 stop noise advantage for full frame, you are still left with a net advantage of 2/3 of a stop at ISO 5000.
Here's the short version.... even though f/7.1 is slower than f/5.6 or f/6.3, the full frame camera can boost the ISO to compensate and still produce an image with lower noise and more dynamic range.
Yes, all things being equal, there is no question that a full frame sensor has better performance than an APS-C at the same ISO. In actually shooting photos, though, there's more to it than that.
First off, the M shooter has options. By design, the M system is not limited to EF-M zoom lenses. You can put an EF zoom on the camera that is more than a stop faster than f/7.1 at 105mm – and has better IQ, too. Or, you can shoot with native or adapted prime lenses that are both faster and sharper than the EF-M zooms. Arbitrarily limiting a discussion of the M system to EF-M zoom lenses is, imo, stacking the deck against it.
I'm going to add that although dimensions and weight do not directly affect IQ, they might affect whether a camera gets used, at all.
A R5 body weighs 738 g, while a M6 Mark II weighs 408 g. A M50 weighs in at 387 g. That's an 80% (or greater) disadvantage to the full frame. The RP (with an older, but still competitive generation of sensor) weighs 485 g, 19% more than the M6 Mark II, or 25% more than a M50.
Camera cost: The M6 Mark II body is now selling for $799. The M50 Mark II is $699. The R5 costs $3,899, the R6 goes for $2,499. So the R5 is 488% dearer than the M6 and the R6 is 312% more expensive. The RP at $899 (or $999 with that "slower" zoom lens) is the only full frame that's competitive on price and weight, although it is still somewhat heavier and more expensive.
I don't think there is a clear winner, or loser here. All these cameras can produce outstanding images. The M cameras blend quality with portability. They have low size, low weight and low cost advantages that, depending on the photographer, may outweigh the better sensor response of their full frame cousins. "f/8 and be there," means you have to have a camera with you!
.......regardless, for low light, f/7.1 is better than any of the ef-m zooms.
Great, I hope you take a lot of fabulous low light photos with it, really. For everyone else I don’t consider it very helpful to focus on just one single, narrow parameter.
To have a proper discussion it certainly helps to focus on the original claim and the (counter) arguments without discussing lots of stuff having nothing to do with the original claim.
For instance, do you often shoot in dim light and how well does the camera-lens combination focus in low light? I have an EF f/4 zoom lens that is slightly better for low light than the aforementioned f/7.1 zoom when used on a M camera. I also have an EF mount 2.8 zoom that betters that by another stop, too.
I know. That's why i use f/1.8 zooms on my M50. Works great. But to your point: It would be interesting to compare AF sensitivity specs (ideally combined with some actual testing) of aps-c mirrorless camera's to full frame cameras to see if there's any equivalence involved for that metric too. The R is Ev -6 at f/1.2. R5 is the same as the R. The R6 -6.5 at f/1.2. The M6mkII is EV -5 at f/1.4. So yes, it seams aps-c as an advantage here when using equivalent apertures. Good point!
The biggest criticism, usually, of the M system is the limited range of lenses. Fine, but the cameras themselves are pretty wonderful imo, especially the M6ii.
That's fine, but it takes both a camera and a lens. In my opinion the somewhat brighter standard zoom is the only thing missing, however, folks should understand that when you want both focal range and brightness it simply can't be compact and light.
That's why - in my opinion - it pays off to have two standard zooms: a big and bright one and a small and dark one. To my eye it's more interesting to combine a 15-45mm or 18-150mm ef-m zoom with an adapted sigma 18-35mm f/1.8 Art zoom than having one compromised zoom being too big for walk around and yet too dark in true low light situations. Weight in your bag isn't as annoying as weight on your camera. Using an ILC you should benefit from it's ability to change lenses. So in my opinion that standard zoom isn't really missing, although, as you can imagine, not everyone agrees with me of course.
Not to mention that every model of M can accommodate lenses that can handle pretty much any photographic situation.
If you want both a large aperture AND stabilization you're trapped. The M system is compact, but when the light gets low you better grab your R6 with a big prime lens out of your bag. Canon really should add IBIS to the M-system. If it's about compact you should avoid carrying a tripod with you.
Just use whatever is best for your overall needs and you can always feel victorious.
It's not about feeling victorious or not. It was about f/7.1 on full frame being better than any ef-m zoom.
victory
 thunder storm's gear list:thunder storm's gear list
Canon EOS M6 II Canon EOS R5 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 35-80mm f/4.0-5.6 III Canon EF 24-70mm F2.8L II USM +18 more
Microprism Contributing Member • Posts: 865
Fake response.
Suit yourself.
nope
not exactly
Yes.
Thanks, your points are equally good.
I have a similar approach except I combine a larger zoom (24-70mm f/4L) that has stabilization (and macro) with a fast prime lens, or two.
Agreed. M cameras are fabulous up to a point. The best compromise for a low light situation is to use a wider aperture stabilized lens like the EF 35mm f/2. This is an area where full frame has the advantage.
Agreed. Victory for each of us is in our results.
 Microprism's gear list:Microprism's gear list
Canon EOS 5D Canon EOS 7D Canon EOS M6 Canon EOS M6 II Canon EF 50mm F1.4 USM +22 more
OP dpeete Contributing Member • Posts: 746
Re: Tamron Still Believes in APS-C
Price announced at $799. Would you spend that on an EF-M version? You’d lose a little on the wide end to an RP with an RF 24-105mm, gain a little on the long end, and get much better AF and faster FPS.
https://www.dpreview.com/news/6450850157/tamron-announces-17-70mm-f2-8-for-aps-c-sony-cameras
 dpeete's gear list:dpeete's gear list
Canon EOS M Canon EOS M6 Sony a7R III Canon EF 85mm F1.8 USM Canon EF 40mm f/2.8 STM +17 more
You'd loose some IQ......
No new gear this Christmas
azed9 New Member • Posts: 21
If it's anything like the old non-VC 17-50mm f2.8, in a flash.
unhappymeal Senior Member • Posts: 1,545
You'd also need to fork over the $1k+ for the RP body.
It's both f/2.8 and stabilized, and especially on the IBIS lacking M system that's a good thing. If it has good sharpness wide open - unlike the ef-s 17-55mm IS USM -  this price seams reasonable to me.
I love 50mm (equivalence)
